How to get the blades off a White riding mower.
   / How to get the blades off a White riding mower. #1
garry
Ohio
JD 1050
My sister has a rinding mower brand name "White". It is an inexpensive mower with a briggs engine and a two blade stamped deck. I would like to take the blades off and sharpen them but I cannot loosen the nut that holds them on. When mowing the blades turn in the same direction I would turn the nut to remove if it is a right hand thread. Before I put a pipe on a breaker bar and stand on it I would like some assurance this is not a left hand thread I am dealing with. Does anyone have knowledge og an opinion? Do you know any tricks or tips? The owners manual says the nuts should be torqued at 100 pounds but does not indicate right or left hand threads.
   / How to get the blades off a White riding mower. #2
i don't think you have a left hand thread. if you have a impact wrench is the best way to remove them. just be sure and put something to lock the blade a 2x4 or something.
   / How to get the blades off a White riding mower. #3
Mix up a batch of 50/50 acetone and ATF......squirt/soak the nut several times.......I bet it will loosen up for you with either a breaker bar or impact wrench. This mix is better than anything on the market.....it works wonders on rust! Good luck.:thumbsup:
2012 TROXELL COMPANY  130 BBL VACUUM TRAILER (A52472)
2012 TROXELL...
2009 Trail King TK110HDG-523 RGN 66 Ton Tri-Axle Lowboy Trailer (A52377)
2009 Trail King...
2014 CHEVROLET IMPALA 4DOOR SEDAN (A54313)
2014 CHEVROLET...
Miller Spectrum 500 DC Plasma Cutting System (A54811)
Miller Spectrum...
Crosley 10ft Hydraulic T/A Dump Trailer (A50323)
Crosley 10ft...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A55301)
NEW HOLLAND 706 30...
