How to get stumps to burn?
/ How to get stumps to burn? #1
CalG
Super Member
vermont
Hurlimann 435, Fordson E27n, Bolens HT-23, Kubota B7200, Kubota B2601
We had a three inch snow fall the other night, and with a "OK to burn when snow is on the ground" approval, I set the brush pile ablaze.
This was not a particularly small brush pile, about 8 feet high and 15 feet around. Started on a bunch of stumps I dug out over the years, with the first one about 8 years ago. The branches and brush just kept getting piled on.
It took about a gallon of old waste oil to get everything going, but the stuff did catch. At times the heat was too much to face even 20 feet away. I tended the burn for over four hours, always trying to get the core that defined the stumps as fuel rich and as hot as possible. The breeze picked up through the afternoon and the fire in that core got mighty hot!
Well, I left the fire when all the small stuff in the area was consumed. (Over four hours)
I went back after supper and "poked the bear", and got more flame licking around the stumps.
This morning I went out hoping to see just a pile of ashes. Hope dashed, the lions share of the stumps were still there. Fire trimmed for sure, but still big old hemloc stumps.
I guess I will just have to bury them!
/ How to get stumps to burn? #2
Dirt doesn’t burn. You have to pick them up with an excavator and drop them to knock the dirt out. 16” or so stumps will clean pretty good but the big ones are slow to deal with.
/ How to get stumps to burn? #3
Wood is pretty fireproof because of the water content. You tried burning them the wrong time of the year. Try in the fall after they have a chance to dry. If you want to help them along, drill a big hole, at least 1", into the heart and fill it with potassium nitrate. Amonium nitrate would be preferred, but it's hard to buy because it is explosive.
I've rolled these stumps around the back area plenty of times. letting the dirt fall. There was some dirt and rocks still, but not much.
Not any where near as much as wood left untouched would suggest.
/ How to get stumps to burn? #5
It also takes a long time for a big stub to burn off. I find it helps to cut them off as short as possible before burning is attempted. I mostly just leave them in a pile or have them hauled off now. You’ll have to mess with a fire for a week straight to make any progress.
