How to get stumps to burn?
/ How to get stumps to burn? #1
CalG
Super Member
vermont
Hurlimann 435, Fordson E27n, Bolens HT-23, Kubota B7200, Kubota B2601
We had a three inch snow fall the other night, and with a "OK to burn when snow is on the ground" approval, I set the brush pile ablaze.
This was not a particularly small brush pile, about 8 feet high and 15 feet around. Started on a bunch of stumps I dug out over the years, with the first one about 8 years ago. The branches and brush just kept getting piled on.
It took about a gallon of old waste oil to get everything going, but the stuff did catch. At times the heat was too much to face even 20 feet away. I tended the burn for over four hours, always trying to get the core that defined the stumps as fuel rich and as hot as possible. The breeze picked up through the afternoon and the fire in that core got mighty hot!
Well, I left the fire when all the small stuff in the area was consumed. (Over four hours)
I went back after supper and "poked the bear", and got more flame licking around the stumps.
This morning I went out hoping to see just a pile of ashes. Hope dashed, the lions share of the stumps were still there. Fire trimmed for sure, but still big old hemloc stumps.
I guess I will just have to bury them!
/ How to get stumps to burn? #2
Dirt doesn’t burn. You have to pick them up with an excavator and drop them to knock the dirt out. 16” or so stumps will clean pretty good but the big ones are slow to deal with.
/ How to get stumps to burn? #3
Wood is pretty fireproof because of the water content. You tried burning them the wrong time of the year. Try in the fall after they have a chance to dry. If you want to help them along, drill a big hole, at least 1", into the heart and fill it with potassium nitrate. Amonium nitrate would be preferred, but it's hard to buy because it is explosive.
I've rolled these stumps around the back area plenty of times. letting the dirt fall. There was some dirt and rocks still, but not much.
Not any where near as much as wood left untouched would suggest.
/ How to get stumps to burn? #5
It also takes a long time for a big stub to burn off. I find it helps to cut them off as short as possible before burning is attempted. I mostly just leave them in a pile or have them hauled off now. You’ll have to mess with a fire for a week straight to make any progress.
/ How to get stumps to burn? #6
In stumps the wood density and water retention just make them almost impossible to burn. You should have tried to split them in a few pieces it would've helped, also the combination of small branches and big stumps don't work well, they end up at the bottom of the fire, covered in ashes and ashes are a good insulator. A big brush fire do emit lots of heat but its all flames and radian heat the actual fire is not that hot, relatively speaking.
So to answer the question ''How to get stumps to burn? '' that be by splitting them in as much as possible, burn with bigger wood (split and unsplit) with it to increase the inner heat, density and longevity of the fire and trying to elevated the stumps so it's not at the bottom of the fire (putting wood under it), you might have got it but regardless Stumps are still a b!@#$ to burn.
/ How to get stumps to burn? #7
If you think trying to burn stumps that are dug up are bad. Wait till somebody tries to burn the stump out of their yard and find that it works about once out of a thousand times, and you get the call afterwards to go grind the stump with all the ash and debris from them trying to light it.
  • Good Post
Reactions: JJT
/ How to get stumps to burn? #8
Get it hot enough and everything will burn
/ How to get stumps to burn? #9
If you can plunge cut a hole through, or long drill, it will burn through faster. Fire needs air, and once you get a hole, any size cut into it, the stump will burn from inside out as well. I've done it on smaller, 24" thick stumps, positioned the cut vertically, and that hole gets larger as it burns. I've found it easier to cut/drill against the grain vs. from the "top" down.
/ How to get stumps to burn? #10
I've burned many a stump..... I've never burned any stumps of size, in one fire. I know going in it might take 2-3 burns but in the end, they've always gone up in smoke.
First burn is to start drying them out and the second/third burn are the burns that actually get rid of them.
/ How to get stumps to burn? #11
I use a leaf blower to get the fire hot enough to start the stump and then pile dry wood around it. You will have to use the leaf blower occasionally to burn the stump.
/ How to get stumps to burn? #12
Bury them. Now that they are scorched, they are pretty much fire proof
