How to get PTO to run w/o being in seat-wood chipper??
   / How to get PTO to run w/o being in seat-wood chipper?? #11
Cinder block(s) should trip the system well.
   / How to get PTO to run w/o being in seat-wood chipper?? #12
you should read your manuals.
1) put tractor in N
2)engage parking break
3) get off tractor
4)pull pto button
5 operate rear pto equipment
Hope this works for you
   / How to get PTO to run w/o being in seat-wood chipper?? #13
Duct tape. Easy on, easy off.
   / How to get PTO to run w/o being in seat-wood chipper?? #14
I use pallet forks on my tractor a lot. Sometimes I need to stand to get a better view while running the forks under my load. I had a spent 410 shotgun shell in my pocket the day I decided I had had enough of my tractor cutting off all the time when I was trying to do loader work. The shotgun shell fit right over the little arm of the safety switch. It was just long enough to hang under a seat support and always keeps the safety switch held down. You could also use any small tubing or pvc pipe to achieve the same results. This same shotgun shell had been on two tractors now. When I upgraded, I moved the shell from the old tractor to the new one. uploadfromtaptalk1464832054934.jpg
   / How to get PTO to run w/o being in seat-wood chipper?? #15
On both my Kubotas, you would flip the seat forward before engaging the PTO.
   / How to get PTO to run w/o being in seat-wood chipper?? #16
I use pallet forks on my tractor a lot. Sometimes I need to stand to get a better view while running the forks under my load. I had a spent 410 shotgun shell in my pocket the day I decided I had had enough of my tractor cutting off all the time when I was trying to do loader work. The shotgun shell fit right over the little arm of the safety switch. It was just long enough to hang under a seat support and always keeps the safety switch held down. You could also use any small tubing or pvc pipe to achieve the same results. This same shotgun shell had been on two tractors now. When I upgraded, I moved the shell from the old tractor to the new one.View attachment 470525
My Kubota has the same switch. Have a zip tie instead of a shotgun shell. I stand a lot to see the tips of my pallet forks.
   / How to get PTO to run w/o being in seat-wood chipper?? #17
Hooked my PTO generator up yesterday on my XR4046H. On HST transmission you set parking brake and put transmission in neutral. Engage PTO, set proper RPM and get off tractor. That's how mine worked. Had no issues.
It was easy. Got on my tractor, started, locked parking brake. Got off and put seat up. Then at a slow rpm engaged the pto. It worked fine. The chipper worked great. Really like this attachment. Oh, I have the Hydro as well. Also I checked my manual and really could not find it there. The way I did it was a recollection of something I thought the dealer told me. Just glad it worked but I will be doing a lot of chipping in the next few years.
Bill
   / How to get PTO to run w/o being in seat-wood chipper?? #19
I wanted to buy the Woodmaxx 8" hydraulic Chipper and their sawmill and they actually said that they wouldn't sell it to me because I live in Alaska! I was going to pay shipping! Guess I'll go with wallenstein and Norwood.
   / How to get PTO to run w/o being in seat-wood chipper?? #20
Nice! Just keep looking, someone will ship. Sad day when no one wants to take your money.
John Deere 5100M (A53317)
John Deere 5100M...
2020 DRAGON ESP...
(2) 48" HANG ON FORKS (A54757)
(2) 48" HANG ON...
2010 FORD F-150 (A58214)
2010 FORD F-150...
CATERPILLAR 255 SKID STEER (A52709)
CATERPILLAR 255...
New Wolverine Sid Steer 3PT Hitch Quick Connect (A59000)
New Wolverine Sid...
