Chipper How to get chipper to throw chips farther?
   / How to get chipper to throw chips farther? #1
Poacher Hater
Is there a way to get my chipper to throw the chips farther? Or is it a function of the rpms off the pto?
   / How to get chipper to throw chips farther? #2
PTO rpm, and size of blower (if there is one).
what is a blower? Can I buy one to increase air flow?
   / How to get chipper to throw chips farther? #5
Are you running pto at 540 rpm?
I'm not familuar with you particular model but generally
The fan is behind the chipper blades it should be radial blades that do the flinging.
pto speed, feed rate, blade sharpness will all affect the throw out of the chute.
tom
Yes, I run the pto wide open.
   / How to get chipper to throw chips farther? #7
you should have a built in blower on the chipper disc. it will look like blades welded onto the back of the chipper disc. In your case theyre bolted. Check their clearance to the shroud around the fan. Look here for parts diagram, #13 is the parts in question. Looks like theyre should be 4 fan blades there.http://www.pequea.com/images/stories/manuals/CX350-Parts1.pdf
run at proper speed as your doing/ Might be worth looking at the chipper blades and disc to check if all the fan blades are there as well as blade condition.
Some professional chippers have a seperate blower that blowes into the chute to increase throw but i havent seen them on smaller machines
How far is your machine throwing chips currently
It throws ok when not CLOGGED! I was hoping to add some extra air flow to prevent the clogging. I am sure my blades are dull but it sure clogs up a lot.
   / How to get chipper to throw chips farther? #9
Can you explain a bit more about how it clogs up, and what the clog is like?
On your model, the blower is part of the chipper head.
And the blades do need to be sharp, otherwise they will just mush the material you put in, and I expect that is what clogs, and why it clogs. Your explanation might differ tho.
the clogs are always in the lower part of the chute...material gets stuck and builds up where the chute starts its bend.
2024 JOHN DEERE 35P LOT NUMBER 107 (A53084)
2024 JOHN DEERE...
2010 Club Car Precedent Electric Golf Cart (A53424)
2010 Club Car...
pressure washer (A55973)
pressure washer...
2016 Toro Pro Force Towable Blower (A50324)
2016 Toro Pro...
PALLET OF (2) SPRINGS (A55745)
PALLET OF (2)...
2003 Walk-Behind Automatic Seed Spreader (A51691)
2003 Walk-Behind...
