How to get a pasture to bare dirt?
   / How to get a pasture to bare dirt? #1
whitravis
3215 Mahendra
I have an acre of field grass. Its also lumpy and bumpy. I want to get rid of the grass and smooth the field with a box scraper. Kill the grass, run a disc over the field, then the scraper box, or??
Or kill the grass then turn it under with a two bottom plow?
33HP
   / How to get a pasture to bare dirt? #2
A lot of farmers would just turn it with a one bottom plow. Let it sit for the grass to die a bit and then disc it. I have reservations that 33hp will handle a two bottom plow.
   / How to get a pasture to bare dirt? #9
First step is to spray it with glyphosate or something similar and kill what's green. For only an acre, I get better results with a tiller and then a drag rather than trying to disc it. Plowing it just makes it much rougher and you need even more aggressive equipment to get it smoothed back out.
YMMV
   / How to get a pasture to bare dirt? #10
An acre, I would just mow it short and run a tiller over it a few times. I've done that on my place with good results. Some around me don't have a tiller and just use a disc. That takes a lot longer, especially in the dry. Discs don't cut very well through roots.
2025 JMR 78in Dual Cylinder Brush Grapple Skid Steer Attachment (A56857)
2025 JMR 78in Dual...
2019 INTERNATIONAL LT625 (A58214)
2019 INTERNATIONAL...
2010 SHOP MADE LIMA MAC 30KW GENERATOR (A58216)
2010 SHOP MADE...
UNUSED FUTURE D39 39" HYD TRENCHER (A58376)
UNUSED FUTURE D39...
1999 CAT 350E2 Haul Truck (A55272)
1999 CAT 350E2...
LOT: Fuel Transfer Tank, Tool Box (NO PUMP) (A59076)
LOT: Fuel Transfer...
