How to get a Bobcat SG60 Stump grinder to work on an ASV?
   / How to get a Bobcat SG60 Stump grinder to work on an ASV? #1
tuckinlugz
Bronze Member
Pensacola Florida Area
2006 ASV RC100 & '06 Kubota R520S
I have a bobcat brand SG60 stump grinder that I want to use on a ASV RC100. The electrical connector is different. Does anyone know where I can buy the male end of the electrical quick attachment so I can rewire it to work on the ASV? Or does anyone make an adaptor? Thanks!
   / How to get a Bobcat SG60 Stump grinder to work on an ASV? #2
go to the asv (or cat) dealer and get the implement side harness and wire it up...they are not cheap however~!
I called them and they were clueless. They said they had a square connector and mine is round.
   / How to get a Bobcat SG60 Stump grinder to work on an ASV? #4
If I can remember I will call a dealership I use alot and see what they say. With as amny different manufacturers they have to make an adapter. I'll let you know. Did you call Beard?
Thanks everyone for your help. I think today finally after a couple weeks of time and research I figured it out. Thanks Dennis from Wisconsin was the guy with the knowledge! Bobcat makes an adaptor that goes from the attachment and converts to a 14 pin connector. For my Stump grinder the SG60 it's part number 6725383 $292.83 and for the snow blower (not sure which model) it's part number 6728165 $194.77. And then you plug the 14 pin adaptor into another adapter that will plug into the Cat Asv 8 pin plug. It's part number 714648 $230. So I thought I would post it up and the next one of you that needs the info won't have to waste all the time I did trying to figure it out. My local Bobcat dealer was clueless. Bobcat of Green Bay knows their stuff! Merry Christmas!
2025 AGT MX-CRT23 (A50123)
2025 AGT MX-CRT23...
2004 Ditch Witch RT70M Ride On Trencher (A53117)
2004 Ditch Witch...
2025 CFG Industrial MX12R (A50123)
2025 CFG...
2025 K2223 UNUSED Double Garage Metal Shed (A53117)
2025 K2223 UNUSED...
2001 INTERNATIONAL 2574 6X4 DUMP TRUCK (A51406)
2001 INTERNATIONAL...
Caterpillar 279D (A50123)
Caterpillar 279D...
