How to Fix a Slow Tire Leak
   / How to Fix a Slow Tire Leak #11
two words....”Flex Seal”
better than nothing as a temporary plug at least
   / How to Fix a Slow Tire Leak #12
I had good luck plugging ballasted tubeless ag tires. Truck and tractor safety seal brand works.
   / How to Fix a Slow Tire Leak #13
I would not think twice about plugging the tubeless tire. It’s a few bucks at risk. Keep in mind you might need a bit heavy duty plug kit handle wise since the tires might be thicker and stiffer than a auto, or that bicycle of years past. It’s very likely to work this time and next time you have a issue you will already have the items :)
   / How to Fix a Slow Tire Leak #14
My 1980 F100 had probably 4-6 plugs in each tire from screws left on the ground after volunteers helped build sets for youth theater in my driveway. Even a magnet on a stick didn't solve the problem of dropped screws. I used one of those plug tools in all the punctures and never had one fail. Cheap fix compared to $15 per plug at the local service station. Once you've done one, the rest are a breeze. However, they don't work for cuts thru a side wall.
   / How to Fix a Slow Tire Leak #15
Just take the tire to a tire shop and have them fix it. Now that that's out of the way,what kind of job do you think I will do cutting my own hair the first time since I was 5 years old?
Dont know of many tire shops that would fix a loaded tire. if anything they would just plug it like the OP could do at home.
   / How to Fix a Slow Tire Leak #16
If a small hole, I've had great luck with plugs. Got refused on a couple holes at tire shops because they were too close to the sidewall (2 fingers), went home and plugged them and good to go for years...Never done a loaded tire but if you do it with the hole up I don't see why it wouldn't work.
   / How to Fix a Slow Tire Leak #17
Once had a leak on my plow truck.
No plugs on hand and about 1.5 hrs to get it fixed.
LOL, hammered a 6 inch nail flat and drilled a small hole to insert a plug.
Next tore apart an extension cord to get the plastic fillers out.
OK, did have some contact cement so I dipped my DIY 'plug' in the cement and proceeded to 'plug' my flat.
I then lit the plug to heat seal that hole.
When I sold that plow truck some 3 years later it still sported that DIY plug!
Lesson learned, I now keep a full plug kit on hand.
But as you would know I have not had a flat ever since then, so I call it insurance!
And, the cost of a kit is but a fraction of a dealer's flat fix price.
Thanks for all the comments, guys. Looks like I should go for a plug kit.
It took me several weeks to get to town and buy a plug kit - with covid I leave the place as little as possible. Then it took a while for warm enough weather to get to the barn and tackle the job. It went smooth enough. I pressure was down to maybe 10 psi, so I took the weight off with the FEL and followed directions to insert the plug. It's been some weeks now and it seems to be holding fine, as many of you said it would. Thanks for the advice.
2014 Ram 1500 4x4 Crew Cab Pickup Truck (A53422)
2014 Ram 1500 4x4...
2018 Ford Fusion Hybird (A53424)
2018 Ford Fusion...
1714 (A57192)
1714 (A57192)
American G-Model Pump Jack (A55315)
American G-Model...
(INOP) 2016 FORD F150 XL SINGLE CAB TRUCK (A51406)
(INOP) 2016 FORD...
2006 FORD F-150XL TRITON EXT CAB TRUCK (A51243)
2006 FORD F-150XL...
