How to fix a leak in a 6 inch water line.
   / How to fix a leak in a 6 inch water line. #1
EddieWalker
Epic Contributor
Tyler, Texas
Several, all used and abused.
Due to my future plans to develop my land, I brought a six inch water line into my land. This is big enough to feed a small city and it will allow me to have a fire hydrant.
After my girlfriend and I installed it, we've had several months of extreme drought. Than the beginning of the year we're above normal rainfall. On Friday night we got 2 1/4 inches of rain all at ounce.
This saturated the land and the fill over my water main. This in turn allowed the pipe to move in the ditch just enough to break the seal on the gasket.
I donated the water line and easement to the Water Departmen and have my meter just at my house. This means that they are responsible for all maintenance and repairs.
This morning they dug up the dirt around the pipe and pumped out the water.
Eddie
They have already cut off the bell in this picture. You can see the black line that indicates how far the pipe has to slide inside the bell for a proper fit. There was enough movement that the black line was visable.
Eddie
After the bell side was cut off, they cut off the other end as well. Turns out the water rushing past the gaskets actually wore a groove into the pipe!!!
Any Stihl fans??
Eddie
To fill the gap, a piece of pipe was cut to fill the space.
Eddie
These clamps were pretty impressive. Stainless steal over rubber with some huge bolts to hold it all together.
They were slid on over the existing pipes, than the patch was put in between. The clamps were slid halfway over the patch and it was all tightened up.
Eddie
They had two 3 bolt clamps, but one was out of shape. Seems it got bent up and the guy in charge said it wouldn't be reliable, so they put in one 3 bolt and one 5 bolt.
The wire is called a "tracer wire" and is used to locate the pipe years from now when nobody remembers where it is.
Eddie
This is the end of the line. Their is a cap on the end of the six inch pipe with a 2 inch galvanized line comeing up to a valve. They screw on a manifold to direct the water away and flush out the lines.
Eddie
It takes awhile for the water to come out clean. They let it run awhile longer and shut it down.
The previous picture was with the valve about halfway open. I asked, but they wont open it all the way!!!
This picture is just before it was shut down.
Thanks for lookging,
Eddie
   / How to fix a leak in a 6 inch water line. #9
Eddie,
I was wondering what that "tracer wire" was for. I thought for a second the guy cutting the pipe in the ditch was going to whack it by accident.
You sure got some big trees on your property. Is it all like that? I didn't expect to see country like that in Texas. Of course I've only been in the West parts on occasion. Thought it would be more prairie or high chaparral country, like you see in cowboy movies.
   / How to fix a leak in a 6 inch water line. #10
We use that wire to be able to locate under ground plastic nat. gas lines. We also use those 360 degree clamps (up to 12" in diameter) to repair broken/cracked gas mains They work very well.
2010 FORD F350 SUPER DUTY SERVICE TRUCK (A54607)
2010 FORD F350...
2015 JOHN DEERE 250G LC EXCAVATOR (A52705)
2015 JOHN DEERE...
2007 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2007 DRAGON 150...
2022 Quick Attach Brush Buster - Heavy-Duty Skid Steer Cutter for Brush and Overgrowth (A53473)
2022 Quick Attach...
2011 John Deere 5075 4WD Agricultural Tractor (A52377)
2011 John Deere...
Toro Workman 200 Sprayer Cart (A50324)
Toro Workman 200...
