HOW TO FIX 1910 3 POINT HITCH
   / HOW TO FIX 1910 3 POINT HITCH #1
stuman
vancouver,canada
1986 ford 1910
I just got this tractor last year, it's a 2 wheel drive and have fixed the clutch, replace all hydraulic oil.Now I'm working on getting the hitch working.The hitch has not worked when I bought it. The guy did not know,why it did not work and he did not do any type of maintence on it at all.
The manual shows the location of 2 different valve bodies on right side.First one is the Priority flow control valve, supplying oil to power steering unit and flow to the next valve. The next is the relief valve/diverter valve.Not clear what this valve controls,,,,,,oil from it goes to the inlet to control to lift and lower of the hitch.
Now the question where do I start at trouble shooting it. I have flow from the pump to the first valve because the power steering is working just fine. Should I take the valve apart before I try to set pressures here first ?
   / HOW TO FIX 1910 3 POINT HITCH #2
Not sure if the 1910's are like my old 1700. It has a metal strainer on the rear axle if this is clogged your 3 point will not work. This can also dead head the pump and kill it. Does the 1910 have a hydrolic filter on it. I know the 1920 has a filter
the manual show no strainer in the tranny housing,just inline filter right next to the pump. There is just a single line coming from the center section of the housing to the pump filter.I think the 3 point oil comes directly from the relief/diverter valve....I am just guessing here,,,looking at the manual.
UNUSED FUTURE AD680 47" HYD PILE HAMMER (A57193)
UNUSED FUTURE...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
UNUSED FUTURE FT-M48 48" HYD MIXING BUCKET (A57193)
UNUSED FUTURE...
gravely riding mower (A55758)
gravely riding...
Loader Forks (A56469)
Husqarvana Riding Mower (A56857)
Husqarvana Riding...
