How to find all backhoe attachments which fit JD790
   / How to find all backhoe attachments which fit JD790 #1
pretendfarmer
WA
John Deere 790
I know that the JD 7 backhoe fits, but they don't make it anymore. Are there any newer model backhoes that will fit? This fitment stuff is difficult to find info on. TY in advance.
   / How to find all backhoe attachments which fit JD790 #2
See one in Arkansas.
   / How to find all backhoe attachments which fit JD790 #3
Your best source is probably going to be old posts here or hopefully old owners. But you are right to expect that subframes can be different for different models. That is why the 3pt mount BH became popular in spite of their many problems and danger - particularly on small tractors.
I beiieve you are wise to only consider subframe mounted hoes even if you have to pay to have the subframe altered.
As for comparing subframes compatibility from one model to the next, I'm not sure that crossover charts even exist. Again, an article where someone has done it is your best bet.
Here is an old thread where a person put a #7 BH on a JD790... but many years ago.
Newer JD backhoe vs older #7 backhoe​
Another thing to consider is that the basic add-on hoes commonly used tractor hydraulics - but most could also be ordered equipped with an optional slide-on PTO driven pump having a fluid storage tank on the BH frame ...usually under the seat.
That PTO driven pump option is just as easy to mount as one using tractor hydraulics and works far better.
We've had both.
rScotty
   / How to find all backhoe attachments which fit JD790 #4
More. I looked at the photo in the adv. To my eye that one looks a little beat. If I were selling it - and it were as clean as he claims then I'd have washed it and assembled so a buyer can see all the parts fitting together. Make sure everything is there and condition.
Price seems high for the presentation. Maybe I'm just out of touch with the times.... maybe....
rScotty
MASSAGE CHAIR (A58216)
SEMI AUTOMATIC QUICK CHANGE FOR MINI EXCAVATOR (A58214)
SEMI AUTOMATIC...
(INOP) RHINO 1310 ROTARY CUTTER (A52708)
(INOP) RHINO 1310...
2017 Kenworth T800 T/A Sleeper Cab Truck Tractor (A55973)
2017 Kenworth T800...
10 X6 MANIFOLD (A58216)
10 X6 MANIFOLD...
2013 John Deere 27D Mini Excavator (A55973)
2013 John Deere...
