Mowing How to figure Rate Per Hour
   / How to figure Rate Per Hour
Well the first go around also included mini excavator work. I charged them $2500. But as far a bush hogging I charged them for 12 hours cause it was a growed up mess. There was also some manaul labor involved in the $2500 price. So for bush hogging it now since it's nice and smooth and spraying it what about $700 per cut and spray includes travel time.
   / How to figure Rate Per Hour #24
How far is the travel time? And how frequent are the cuttings? if once per year, it is going to be thicker and slower going. IF 3 or 4 per year, you can go faster.
And how smooth was it?
Basically, you can see what I am getting at. How long do you think it will take from your drive, BACK to your drive? Take that number x $60 and thats the ballpark I would be in.
If that number is 9-10 hours, and you want to charge $1500, you are charging $150+ per hour. Which WAY too high for the equipment you have.
The $700 is probably reasonable considering the cost of spray and time involved with that.:thumbsup:
My thoughts too, I knew I was way to high on it, just had a gut felling that I was fixing to bid my self right out of a gravy job. The field is relatively smooth and not a lot to go around. They are wanting it cut three times a year and sprayed each time also. So I'll say $60 hour @ 8 hours plus $70 to cover spray plus an hour to spray cause there's not a lot, and then $40 for drive time. 60*8+70cover spray+50 for hour of spraying+40 travel=$640 per cut. If say that's pretty reasonable.
   / How to figure Rate Per Hour #26
Sounds good to me. Certainly alot better than $1500
Last question, say I was to get a 12ft cutter and different tractor and could mow that 20acres a little faster, would I need to adjust my price up or down because of the cost of equipment, I know dumb question but to me there is never a dumb question just a dumb *** for not asking someone a question. Thanks
   / How to figure Rate Per Hour #28
No way they are paying you for the job you do not for how quickly you do it. I wouldn't bid any lower than 1 grand on this. You are doing this as a business not just for wages
I just bid it at $750 per cut, and they accepted. Do you think I'll lose my .... on this job.
LD1 i put a bid in on that 20 acres for $750 per cut and spray. They accepted. Hopefully I dont lose my *** on this.
Sunray Family Fisher 17.5 18' Pontoon Boat (A53316)
Sunray Family...
2013 Yale Forklift (A56435)
2013 Yale Forklift...
excavator trenching bucket- one bucket per lot (A56435)
excavator...
2005 PETERBILT 379 TRI AXLE  DUMP TRUCK (A58018)
2005 PETERBILT 379...
JOHN BLUE 1000 GALLON NURSE TANK (A52708)
JOHN BLUE 1000...
2 DISC TILLER W/ FARMALL MOUNTS (A52708)
2 DISC TILLER W/...
