How to Easily Remove Grease and Diesel Smoke From Your Tractors Loader (Video)
   / How to Easily Remove Grease and Diesel Smoke From Your Tractors Loader (Video) #1
94BULLITT
Super Member
USA
yes
I figured out an easy way to remove grease and diesel smoke from your tractors loader. I made a video so you can see how it works.
   / How to Easily Remove Grease and Diesel Smoke From Your Tractors Loader (Video) #2
Thanks for the tip- WD40 makes sense, and I hadn't thought of it! I do know about Rejex, though.
Your welcome, a can of WD40 was sitting by the loader and it gave me the idea to try it. Rejex is some good stuff.
   / How to Easily Remove Grease and Diesel Smoke From Your Tractors Loader (Video) #4
Ok, I'll bite: what's the story with Rejex? What have you guys successfully used it on? Anybody used it on boat gel coat?
   / How to Easily Remove Grease and Diesel Smoke From Your Tractors Loader (Video) #5
I've posted this before, but here goes: Rejex is originally made for protecting the paint on aircraft from nasty jet exhaust stains. You apply it like wax, but it requires very easy buffing. It is a trick synthetic compound that resists water, airborne crude, bird droppings, jet exhaust, tractor exhaust, and 600 mph air streams. I had replied and posted a photo back in the beginning of Aug. is thread called "Removing Diesel Soot From a Loader Frame" started by Industrial Toys. Can't find the photo at the moment in my TbN files.
   / How to Easily Remove Grease and Diesel Smoke From Your Tractors Loader (Video) #6
be careful, looks good at first but I've had it dull paint - takes the finish off. I used it on a bicycle and it took the finish off and now that area is dull.
   / How to Easily Remove Grease and Diesel Smoke From Your Tractors Loader (Video) #7
So, it is great,it sucks? Gelcoat on boats?
   / How to Easily Remove Grease and Diesel Smoke From Your Tractors Loader (Video) #9
Maybe test in a small inconspicuous area?
Rather not spend $ on something that might or not work as advertised.
   / How to Easily Remove Grease and Diesel Smoke From Your Tractors Loader (Video) #10
I clean my aircraft undersides with Go-Jo (the original, NOT the pumice version). Wipe it on by hand or rag, wipe off with a rag. It removes oil, grease, and really hard to remove avgas (lead) stains like magic. Haven't tried it on the tractor . . . never thought to.
If you consider WD-40 is a good solvent (and it is for some things), it's mostly light oil so you can save money over WD-40 by using kerosene, paint thinner, Stodard solvent, or oderless mineral spirits.
1995 Koehring LRT-110 7.5 Ton 4WD Rough Terrain Crane Truck (A55787)
1995 Koehring...
2019 Kubota RTV-X1140 4x4 Diesel Utility Cart (A56857)
2019 Kubota...
EZ-GO Utility Cart (A55853)
EZ-GO Utility Cart...
2013 Audi A4 Sedan (A55853)
2013 Audi A4 Sedan...
72" HYD QUICK ATTACH GRAPPLE (A51406)
72" HYD QUICK...
2004 Pierce Tilt Crew Cab Enforcer Fire Truck (A55853)
2004 Pierce Tilt...
