How to drill a shallow hole in sheet metal?
   / How to drill a shallow hole in sheet metal? #1
N80
Super Member
SC
Kubota L4400 4wd w/LA 703 FEL
I need to drill a hole in some sheet metal...not on a tractor...but we'll pretend that it is. I have no way to tell what is behind the sheet metal on this particular machine. Probably nothing but I don't want to go shooting a drill bit through there where I don't know if there is a wire or a fuel line. Is there a better way of making a depth stop than just wrapping a big gob of tape around the bit? I'd Google it but I don't even know what to call such a device. Thanks.
Ooops. Never mind. As it turns out they are called depth stop drill bits. Who knew?
   / How to drill a shallow hole in sheet metal? #3
I knew.
And would have told you. :D
Thanks. Its the thought that counts. ;)
   / How to drill a shallow hole in sheet metal? #5
What size hole? A small hole saw might do it. Or for sheet metal, maybe just grind a hole through with a Dremel carbide bit and then enlarge as needed.
   / How to drill a shallow hole in sheet metal? #6
OR.
Use a step drill. No center punch mark needed. Just drill to the first step. Check for obstructions then use the same bit to enlarge to desired size.
Terry
   / How to drill a shallow hole in sheet metal? #7
masking tape wound around the drill bit is all it takes. ;-)
   / How to drill a shallow hole in sheet metal? #8
Drill through a piece of dowel and leave just enough sticking out.
   / How to drill a shallow hole in sheet metal? #9
You must first convince the sheetmetal it wants to be drilled :D
   / How to drill a shallow hole in sheet metal? #10
I have used 2-pc locking collars before.
I dont trust tape. Sometimes if the drill bit grabs as its punching through, the tape dont stop it
UNUSED AGT QUICK ATTACH DROP HAMMER (A51244)
UNUSED AGT QUICK...
2016 Takeuchi TL8 (A47384)
2016 Takeuchi TL8...
UNUSED CFG Industrial MX12RX Mini Excavator (A47384)
UNUSED CFG...
2015 Dodge Charger Sedan (A50324)
2015 Dodge Charger...
2017 Rogator RG1300B Dry Fertilizer Applicator (A52128)
2017 Rogator...
Agco 4227 4 Star Tedder (A50774)
Agco 4227 4 Star...
