Backhoe How To? Drain old Hydraulic Fluid from Backhoe?
   / How To? Drain old Hydraulic Fluid from Backhoe? #1
Ron_NY
Central NYS
Belarus 525
Any suggestions on how to drain a backhoe of its old hydraulic fluid? It has been sitting for serveral years (a most interesting lawn ornament), and I have no idea what type of fluid it has. I am concerned about mixing the old fluid with my tractor's hydraulic fluid.
Thanks for your help. Ron in Central New York
   / How To? Drain old Hydraulic Fluid from Backhoe? #2
The only way to completely purge the system of any traces of old hydraulic fluid is to remove all components, lines cylinders, etc, disassemble and clean.
   / How To? Drain old Hydraulic Fluid from Backhoe? #3
Hook up the pressure line, pull the quick connect off of the return line, stick the line in a bucket and cycle all of the hydraulics. Have hydraulic fluid on hand to refill your tractor while you're doing it.
   / How To? Drain old Hydraulic Fluid from Backhoe? #4
Have your engine on idle while cycling the cylinders otherwise you will fast drain your reservoir.
2003 International 9200I (A53317)
2003 International...
UNUSED FUTURE FT-RT57 - 57" HYD ROTARY TILLER (A52706)
UNUSED FUTURE...
UNUSED FUTURE HYD HEDGE TRIMMER (A52706)
UNUSED FUTURE HYD...
2014 Ford F250 4x4 Crew Cab Pickup Truck (A55973)
2014 Ford F250 4x4...
PAINT ROOM EXHAUST FAN (A54757)
PAINT ROOM EXHAUST...
2019 Ford Explorer (A55788)
2019 Ford Explorer...
