How to disable reverse PTO kill switch?
   / How to disable reverse PTO kill switch? #51
</font><font color="blue" class="small">( ...The kill switch on the seat is a safety hazard. When I duck to mow under low-hanging branches, either forward or to either side, my weight comes off the seat switch and the motor dies... )</font>
Heheee.. I hear ya. That's bad enuf, but when the 'seat switch' is activated, it just kills the ignition & not the fuel cutoff solenoid, so the tractor will give you a nice BANG out the exhaust, or will diesel as it coasts down. My 2544 will anyway once she's good and hot. The REV tech feature is nice, but you have to remeber to reset it anytime the seat switch is activated. I still keep forgetting to reset that darn thing !@#$.
G/luck
Joel
   / How to disable reverse PTO kill switch? #52
i have a gt 1554 and all that you have to do is put the key in the middle position and push the button and it will mow in reverse till you kill the motor or put the key in normal mowing mode anotherthing idid on my dads mower was just remove the wire to the reverse switch
Neckover GL24-2-7K Gooseneck Trailer  24ft Deck, Dual 7K Axles, 14K GVWR (A56435)
Neckover GL24-2-7K...
Case Axial-Flow Combine Wheels NO RESERVE (A55315)
Case Axial-Flow...
2020 MACK P164T (A58214)
2020 MACK P164T...
2007 Ford F750 (A55973)
2007 Ford F750...
2012 Ford F-550 Knapheide Service Truck with Liftgate (A56858)
2012 Ford F-550...
2016 Isuzu NPR Landscape Dump Truck (A56858)
2016 Isuzu NPR...
