How to Defrost Rear Window
   / How to Defrost Rear Window #1
OrangeAgain
Albany, Vermont 05820
2015 Kioti RX7320PC, 1983 Kubota L275 4WD, 1981 John Deere 2440 2WD row crop tractor
Used my new Kioti RX7320PC yesterday for the first time in cold, snowy conditions. All the windows defrosted reasonably well after adjusting the heater vents except the rear window which does not have a vent. There is a circulate / recirculate / outside / inside air vent over the rear window however it doesn't seem to have much flow effect.
How does the rear window get defrosted?
   / How to Defrost Rear Window #2
My cab is a DIY project and I also needed to defrost rear window.
My solution was to mount a small (3") muffin fan in such a way that it blew air over the affected area.
The moving air combined with the fact that it is somewhat heated cabin air does the trick.
In my case the fan is attached to a magnet which allowed me to position as required for best results.
   / How to Defrost Rear Window #3
Another option is to get an aftermarket stick-on element style defroster and wire it into a switch. Unfortunately, they don't go on too well in the cold....the adhesive doesn't like to stick to freezing cold glass! I put one on the rear glass of my Land Rover and it's great! Now that I think about it I might do it to my tractor too!! And put a seat heater in!!!
   / How to Defrost Rear Window #6
Have you considered one of the small 12v fans that will blow the warm air onto the rear window?
I have used a 5" fan to move air to the rear of a cargo van to help warm it up in the back. It plugs into a lighter outlet or as I did wire it to a switch.
PowerBoss Admiral Plus 38C Ride-On Floor Scrubber/Sweeper (A55851)
PowerBoss Admiral...
Enclosed Service Truck (A55788)
Enclosed Service...
2015 POLARIS 1000 HIGH LIFTER RAZER (A57192)
2015 POLARIS 1000...
2023 Caliber Trailers GH840MST 40ft T/A Gooseneck Flatbed Equipment Trailer (A55851)
2023 Caliber...
2006 Hyundai Sonata Sedan (A55853)
2006 Hyundai...
44052 (A55852)
44052 (A55852)
