How to Cut a Field
   / How to Cut a Field #21
Jeanne – Is this diagram (attached) what you mean as far as cutting the diagonals first? That seems like it would work pretty good. It has the effect of rounding off each corner so you could make the turns without having to back up once, or loop back around. If it ever stops raining, I’ll give it a try.
   / How to Cut a Field #22
Very interesting idea with the diagonals. I may try that this weekend if time allows. This is a great thread to read, but I remain a little envious of those of you with rectangualr fields, or who can at least impose a rectangle onto a given area. In my 25 acres, I don't have any right angles, or even four-sided fields, for that matter---just very polygonal fields and lots of out-buildingsand trees to disrupt a pattern.
   / How to Cut a Field #23
jrdellaratta - I know what you mean, I don't have rectangular fields either, mostly diamond shapes. But, the diagonals should still help. Got another inch of rain and it still raining though, so it will be a while before I can mow anything.
   / How to Cut a Field #24
Now I'm envious of your rain! We're in the midst of a pretty serious drought in Maryland---more than a 12" rainfall deficit from September, I'm told.
   / How to Cut a Field #25
Well, I tried doing the diagonals yesterday and it worked good. I still had to back up and make a 3 point turn or swing around on one of the corners at the top of the “diamond” where it’s really sharp, but I was able to make the other corners easily. I think it did cut down on the mowing time, but it was hard to tell because I had to go a little slower than normal because the grass was real thick, tall, and wet (even on the hill) – I was mowing in mud and standing water in several places. Next time I might try starting in the middle and working my way out – that way I’ll be going downhill all the time instead of up hill all the time (the center of the field is pretty much where the top of the hill is). This pattern should really work good on a more rectangular field.
   / How to Cut a Field #26
There's one born every second but it works for me. Depending on discharge of implement or not-------go to as close to as possible dead center of field; cut the tightest circle possible and mow with out stopping, in the end you will have the opposite of what you would have had other wise. Sometimes I get boared. BUT in the begining your cut will have no overlaps and from the sky look like a space landing. best to y'all
   / How to Cut a Field #27
Mosey,
Sorry I couldn't reply sooner.... But you got it right. Glad to have been of any help...
Jeanne
Year: 2014 Make: Ford Model: Fusion Vehicle Type: Passenger Car Mileage: Plate: Body Type: 4 Door (A56859)
Year: 2014 Make...
Adams 5T HC Spreader (A55301)
Adams 5T HC...
2021 Fleco DX140 24in Tooth Bucket Excavator Attachment (A55973)
2021 Fleco DX140...
12in Digging Tooth Bucket Excavator Attachment (A53421)
12in Digging Tooth...
2016 Lincoln MKC SUV (A55853)
2016 Lincoln MKC...
2011 DOOSAN G40 GENERATOR (A53843)
2011 DOOSAN G40...
