How to connect external PVC electrical conduit to interior box?
   / How to connect external PVC electrical conduit to interior box?
Here are some pictures. I made an unwelcome discovery also. Where I want to trench is within the canopy of some gigantic oak trees. I might move a ways down the building away from the trees to trench. But I can't very easily trench along the foundation.
I guess I could run some 2" conduit above grade and outside of the barn to move away from the trees, and fasten it to the concrete foundation of the barn? I could do it with a few LB's and still only have two 90's below grade. A sweep going down and a sweep coming back up.
One picture shows the wires that feed the existing Zinsco panel. I put a tire pressure gauge next to them for reference about their size.
One picture shows an electrical switch in an unfinished wall of the garage that I want to pull power to. This is near the location where I would put a sub-panel. (That switch was somehow in past days connected to a long extension cord in the barn.)
BarnToGarageA.jpgExistingFeedA.jpgGarageToBarnA.jpgPanelLocationA.jpgZinscoPanelA.jpg
   / How to connect external PVC electrical conduit to interior box? #22
Are you getting rid of the Zinsco panel? They are like Federal panels are today. Breakers not considered reliable (maybe dangerous), modern features/requirements not available, parts not available except on the used market, breakers when available get pretty expensive. I know an old electrician who salvages all the old stuff and sells parts. He even has a bunch of brand new. He always said; "someday this stuff will be valuable". He even had a lawyer draw up a non-guarantee that he makes buyers sign.
Ron
   / How to connect external PVC electrical conduit to interior box? #23
For the price of a small panel like that, I'd have your friend change it over to a newer one in a heartbeat, especially if they have a "reputation"...just saying. He might even have a used one on the truck you could use.
Thanks to all for helping me complete this project. I cannot believe it took most of 3 1/2 days to trench, lay conduit, backfill, route above grade conduit, penetrate the wall, and pull wire. I still need to fasten the conduit to the concrete foundation, which I could not do as I didn't have a roto-hammer. If I were paying someone by the hour to do this, in the same amount of time I took, I might have fired them for milking the hours on the job.
Trenching between two buildings close to each other was a challenge. Digging was easy, but I ended up with my SCUT marooned in the center while straddling the recently dug trench. It took some juggling of 4x4 posts, some 3/4 plywood, and a little manipulation of the hydro pedal and backhoe to encourage it back to safe ground without dropping a wheel in the trench.
I installed 2in conduit for the high voltage, and 1in conduit for the low volt/internet, etc. Glad I used the bigger pipe for the high voltage.
2015 AMERITRAIL MANIFOLD TRAILER (A55745)
2015 AMERITRAIL...
UNUSED KIVEL 3500# PALLET FORKS (A54757)
UNUSED KIVEL 3500#...
Rhino 8' 3pt. Blade (A50775)
Rhino 8' 3pt...
2014 Jeep Patriot SUV (A53424)
2014 Jeep Patriot...
2016 Club Car Carryall 1500 4x4 Utility Cart (A53424)
2016 Club Car...
2025 JMR Tree Boom Skid Steer Attachment (A53421)
2025 JMR Tree Boom...
