How to clean out fuel tank?
   / How to clean out fuel tank? #1
Richard
Super Member
Knoxville, TN
International 1066 Full sized JCB Loader/Backhoe and a John Deere 430 to mow with
We've got an IH 444. The fuel tank does NOT appear to be removable at all or if it is, not without GREAT hassle.
Machine has been cutting out on us and I've now ascertained it's a fuel flow problem. Blow air backwards into the fuel line (at the filter) and the fuel then comes GUSHING out the line. Bottom line, I've got a restriction of gunk in the tank.
I've been trying to slowly use up the fuel. Unfortunately, I'm a "good boy" and keep ALL my dieselt tanks FULL so I can't just empty the tank out although I did buy another 5 gal diesel can yesterday to siphone some out.
Ok... so here's my plan:
Take a siphon hose and siphon as much as 5 gallons out of the tank into the empty can. While doing so, use the submersed part of the hose as a vacume cleaner in hopes of sucking up some things and dropping them into the can. I plan on using an old pair of my wifes hose (as in LLegs :eek: ) as a possible filter unless someone has a better idea.
If I can suck all the muck out, great. If not, then here is the crux of my problem.
If the fuel tank is empty with crud in the bottom, just how do you flush it out? The fuel line is something like 1/4 inch the opening for the fuel cap is something like maybe 2 inches wide? The tanks depth is something like 18 inches? (wild guess)
How on earth do you go through a tiny hole like that and clean up things down there? If I were a proctologist I might have nice tools for that but I'm not! :eek:
My backhoe has a fuel tank cleanout which is something like a 1 inch hole I can open up and flush everything out with water (I later take a garden sprayer with diesel and "pressure wash" the tank out with diesel before filling back up)
This tractor seems to also have a cleanout but it too...seems to be only about 1/4 inch.
How do you guys do it with the tank still installed?
   / How to clean out fuel tank? #2
Mornin Richard,
The only problem with what you have planned is that you will undoubtedly get all the loose crud out of there. The problems lies in the rusted bottom section of the tank, the rust scales will keep falling off of the tank interior. When I restored my Super A last year, only a 10 gal tank BTW I removed the whole tank and strapped it onto an old paint mixer, I dropped a box of locknuts in there with some moneral spirits and let it spin a few hours. That tank came out like brand new inside :) . I thought I was going to have to coat the inside with Eastmans, but I just didnt need to. The bottom line is that you may get away with what you plan on doing for awhile but I think you wilkl still have problems down the road ! IMHO !
Had never thought of rust scale inside the tank?? :confused:
Isn't that less likely if the tank is always kept filled? The sides of the tank that ARE within sight to see (using a flashlight too) don't show any signs of flaking.
I was really presuming (hoping?) it was just years worth of a blade grass here & part of a leaf there that have finally added up.
Guess it'll be interesting to see what I find once I can draw the level down.
   / How to clean out fuel tank? #4
Richard,
If no rust is flaking you could possibly be OK with your method. Make some tools up to get inside the tank filler and use a length of hose off of the outlet to run any crud into a bucket. Usually you can see the rust on the bottom/sides of tank using a flashlight. Hopefully some cleaner/solvent sloshed around in there will solve your problems !
   / How to clean out fuel tank? #5
Keeping the tank filled leaves less airspace and thus less area for condensation to form - any water that does form and/or comes with your fuel goes straight to the bottom of the tank, that's why the bottoms rust.
   / How to clean out fuel tank? #6
I just cleaned out an 8hp Honda tank that had gunk in the bottom. I also cleaned out a Clark Forklift Gas tank a couple years ago that had been sitting for a while.
I have a Jenny Hot Water Pressure Washer. I flushed out the Honda for a few minutes until it was clean. The Clark took longer, about 30-45 minutes with hot water. Drain, then blow dry with compressed air.
Years ago I worked at Fruehauf repairing semi trailers. We used to repair gasoline tankers. If we had to weld on them we put a steam cleaner in the tank and let it run for about 4 hours to clear the tanks. We checked it with a explosimeter every hour while working on it.
   / How to clean out fuel tank? #7
I would get all the fuel out, Then add some water then shove a wetvac hose in and suck the water and crud out.,
   / How to clean out fuel tank? #8
I wonder if putting a low pressure, low volume air pump on the fuel line to blow air into the tank to keep it stirred up while you are removing the fuel from the tank would help. Something along the lines of an oil-less 12v pump is kind of what I had in mind. Be sure if you try this, to keep the pump above the level of the tank, such as sitting on top of the tractor, as you don't need the fuel running downhill into the compressor should it happen to stop for some reason. Also, make sure to that you remove all forms of fire and ignition from the area, as fuel fumes are more subject to burning than just plan diesel fuel. This might clear the screen as well as keep the liquid stirred up enough to allow you to syphon more of the crud out. You won't be able to syphon around the area where the air is coming out because it will allow air into the hose, killing the syphon, so you might want to run the compressor for a few minutes, then either shut it off, or make sure it is flowing ok and the pickup tube is away from the air path.
David from jax
   / How to clean out fuel tank? #9
You failed to mention how many gallons the tank holds full. If it holds 8 or ten gallons full, better pick up another 5 gallon diesel can. Next you might consider a" mighty vac", a hand operated vacuum pump available at better auto parts stores and wall mart. It creates a vacuum and draws liquid and small particulant-sludge up into a approx 4 oz container that can be cleaned and emptyed. and started again. It does a good job on brake lines-vaccuum bleeding and cleaning sludge out of master cylinder {from top opening not remote opening}.
   / How to clean out fuel tank? #10
Have you inspected the fuel outlet closely? The whole outlet assembly may come out and may even have a screen filter.
Speaking of filters, Use a 2x thickess of high quality paper towels on top of a large coffee filter. Won't get everything,but it will get a lot.
jb
   / How to clean out fuel tank? #11
I cleaned out a Corvette fuel tank many years ago, it was a 1975 with a large opening for little kids to climb on the back and put sand and small rocks in it, I used a vacuum cleaner and a garden hose to get in the tank and suck sand and dirt and small rocks out, changed fuel filters and the car was great !
6 feet of garden hose and some duct tape and a vac will do the trick when you have all fuel out and dried and have fumes evacuated, they will not like the sparks from vacuum motor at all
Well, here's the rest of the story.
First, the tank holds (I'm guessing) over 10 gallons of fuel, or maybe right at 10.
We've been running the tractor between its stopping so it had about a half tank.
I bought a new yellow can and drained as much into it as I could. I topped the already topped backhoe off and with that 2 pints voided, was able to take the tractor tank to about 100% dry.
Upon looking in there which was VERY difficult to do I might add, I saw nothing. I really expected to see a fist sized amount of leaves, muck, sticks, stones or maybe even the lost pair of socks that go into my dryer but never come out :eek:
NOTHING
:confused: :confused: :confused:
I KNOW for a fact that this is where the issue is because of the no flow situation I have at the fuel filter (then after blowing air through it, a GUSHER of fuel)
I kept looking....
Finally, I'm forced to belive that I found it.
About 1/4" long and maybe just a bit thicker than a pencil lead. I don't know if it was a twig or some compressed dirt but I happened to have one of those reaching tools with a claw on the end and was able to extract it.
That is the ONLY thing I saw in there that was too big to fit through the fuel hole.
Also... I started the tractor up (prior to drying the tank out 100%) and was intrigued to see the amount of fuel returning from the return line. What THAT inferred to me was just how much was being sucked into the feed side. If I have that much being fed into the feed side, then just perhaps this little twig WAS enough to be caught in the flow and become an unwitting plug.
I also took the filter off and found some more "bits" in there that have made their way through so it's quite possible that I might have had a plug that has since broken up and been sucked out. I told my wifes cousin (tractor owner) that he might want to pick up another filter just so we can throw this one away.
The tractor was refueled and is now waiting for use. I'll be interested to see if we have any more issues.
   / How to clean out fuel tank? #13
Mornin Richard,
If thats the worst that has happened so far I would consider you lucky ! ;) I will be waiting to see how the tractor performs now !
   / How to clean out fuel tank? #14
Ive been watching this thread to see solutions. I have a case 970 with what looks like sedimate in the tank kinda looks like paint that has been stripped. Note that this tractor had been sitting for a while before i bought it. Ive took the tank off and tried rinsing it out no small feat here it has a 50 gallon tank but i still have the junk in it. A pressure washer wont work due to the shape of the tank no way to reach it all. Any ideas out there?
   / How to clean out fuel tank? #15
Your solution reminds me of a similar occurrence I had a few years ago with a D-14 Allis. The tractor would start to stall when it got to about 1/4 tank. Looked and looked, problem plagued me all summer, till I finally cpotted the culprit, floating in the gas. Key word here is floating, as in sits on the surface of the gas, until the tank gets low, then it gets sucked down into the inlet of the bowl. It was a big bumble bee!:D Remember to check the top surface of the fuel, too:D
2013 JOHN DEERE 772G MOTORGRADER (A60429)
2013 JOHN DEERE...
2021 Kubota RTV-X1140 4x4 Diesel Utility Cart (A59228)
2021 Kubota...
24220 (A56859)
24220 (A56859)
2019 CATERPILLAR 303.5E2 CR EXCAVATOR (A60429)
2019 CATERPILLAR...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A55315)
NEW HOLLAND 706 30...
2005 TerraGator 8104 (A55302)
2005 TerraGator...
