how to clean mower deck
/ how to clean mower deck #1
Anonymous Poster
Epic Contributor
I'm sure this has been hashed-out in the past (although I couldn't find a thread using the search utility)...
How do you clean a mower deck of built-up crud? I bought my Simplicity Legacy in the spring as a demo (just laid sod in the front yard and seeded the back yard so I haven't had a need for the mower yet). I noticed that it had been used to mow with but didn't realize exactly how much crud was built-up. Are there any cleaners that will loosen-up this stuff so that I can scrape it off? I've heard others warn against using a powerwasher, but could one be used if you cover-up the important areas (if so, what areas would those be)? This is going to be my winter project in the basement but I wanted to get some opinions.
Thanks in advance.
I have been mowing with a Scagg and after each use, I use a power washer to clean it up. I am careful not to get the motor wet and I regrease any fitting that was washed. If some paint comes off, I figure that it was not applied correctly from the factory and would be rusting underneath anyway. I just apply some primer and touch it up at the end of the season. If you start scraping the old buildup, you will probably introduce scratches and new rust.
/ how to clean mower deck #3
I still think a power washer, or even a garden hose spray nozzle if you have enough water pressure, is the best way to clean one, and I don't worry too much about getting any water in the wrong place. I just wash everything as well as possible, but then run it long enough to dry everything and grease any grease fittings.
Bird
/ how to clean mower deck #4
This is the way that I have always cleaned my deck. Don't know if it's the best way, but my lawn tractor deck has lasted 12 years without a sign of rust, nor loss of paint. Once a year (usually late Autumn), I scrape the deck bottom with a hard plastic (it may be teflon) putty knife. I don't get it absolutely clean (don't want to scrape the paint off), but it gets the big stuff off. I figure that dirt is OK, but clods are not (moisture holders).
/ how to clean mower deck #5
Tony,
Last year a gentleman pull into the car wash in his pick,and with a hand full of quarters he wash..rinse..wax the mower deck,yep I to talk a walk over and notice for he did a great cleaning job. [shock]
Oh yes he also had to wash his pick up afterwards. /w3tcompact/icons/laugh.gif
So maybe a good pressure washer the answer for you. /w3tcompact/icons/wink.gif
Hope you have a pleasant weekend.
Thomas..NH /w3tcompact/icons/wink.gif
Me, I never use water. Compressed air, scrape if necessary. Repaint with half used spray cans any color scratched or not. My deck has lasted almost 40 years.
2023 Stearling Trailer (A60352)
2023 Stearling...
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC55 55ft. Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
2020 Kenworth T680 Sleeper (A62613)
2020 Kenworth T680...
JOHN DEERE 544J SUPER TRACTION WHEEL LOADER (A65053)
JOHN DEERE 544J...
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
John Deere X380 Riding Lawn Mower (A66285)
John Deere X380...
