How to Choose Replacement Car Parts
   / How to Choose Replacement Car Parts #21
I use a blow gun with the rubber tip removed and a peice of brake tubing screwed in place, to blow any debris from the plug wells, before removing the plugs.
Definitely do this ^
Also, w 100K after I blow out the SP wells, I squirt some (insert your favorite penetrating oil here) in there and let it sit for awhile. Sometimes even warm up the engine for 5-10 min, then squirt, and let cool for awhile.
   / How to Choose Replacement Car Parts #22
I've got a 2004 Taurus nearing the 100,000 mile mark. It has been a great car needing just tires and brakes. So I figure it probably needs spark plugs, new serpentine belt, PCV valve, coolant, etc.
I like the convenience of Rock Auto, so I start looking for parts and for every component they have a bunch of alternatives. How do you choose a part these days? Does the Goodyear or Dayco name on a hose mean anything?
And what about plugs? Platinum, double platinum , iridium? Champion, NGK, Bosch?
Thanks in advance for your thoughts.
Man o' man, I have just went through what you are going through. I will take Dayco or Goodyear. Look for the heart symbol because that is what most people chose. As for the plugs, I read a great many of reviews on the types, and just used my head to guess which of the manufacturer's comments made the most sense. I like to use OEM equivalent plugs insofar as possible since I don't want to get into deciding heat ranges, etc.
The first thing I do with any "new to me" vehicle is understand the timing belt status. Next, the valve adjustment status. Once I know that, I plan a major PM where I adjust the valves, replace the timing belt, drive belts, cam seals, crank seal, hoses, and anti-freeze, all fluids including brake fluid, rotate the tires, and whew...I'm done.
2012 DODGE RAM 5500 FLATBED (A58214)
2012 DODGE RAM...
SOFTBALL & BASEBALL HITTING & CATCHING GEAR (A58374)
SOFTBALL &...
DOOSAN 8000# PNEUMATIC FORKLIFT (A58214)
DOOSAN 8000#...
2017 Ford F-350XL (A57148)
2017 Ford F-350XL...
2016 WINNEBAGO SCORPION 4014 5TH WHEEL CAMPER (A58214)
2016 WINNEBAGO...
2018 JAGUAR XE (A56859)
2018 JAGUAR XE...
