How to choose flux core wire?
   / How to choose flux core wire? #21
Yes but the same principal applies. Even with SMAW, There are three to four small zones where the voltage changes. I try to set my voltage to hit the sweet spot at about 3/8-inch stick out. To a degree if I want a hotter / more flowing puddle I'll open the stick out to say 1/2-inch. But if I go too far, say 3/4-inch, I'll run the risk of losing the arc. If I want a cooler / stiffer puddle I'll shorten the stick out to say 3/16 of an inch.
Same with SMAW, want a colder puddle jam the rod right into the puddle. Want a hotter more flowing puddle back the rod out some.
With self shielded T-8 wires, and dual shield most of those wires require 3/4 to 1 1/4-inch stick out.
Are you talking about running your engine drive with an Ln-25?
I've not run one so I can't say what it does.
I obviously agree with SMAW the arc voltage is adjusted by shortening/lengthening the arc.
But with a constant voltage power source I disagree with your description of FCAW.
Only my .02 - nothing more. :)
   / How to choose flux core wire? #22
Give it a try Dave, and see what you think!;)
Remember now, I've only been welding a few weeks.:D
   / How to choose flux core wire? #24
Dave remember that 120-volt Mig welder of Roadhunter's I had. Here is one of the first welds I made with it. See how the crater / stop is full? I shortened the stick out, and backed up some.
Shield. I took a couple more pics today. Didn't get to do any welding today.
Oops forgot the picture.
Second picture.
   / How to choose flux core wire? #28
It's really hard to tell with all the slag still on the weld. Do you have one of these?
Here's what they do to self shielded flux core slag.
   / How to choose flux core wire? #29
Here you go Dave. I found this in a ESAB pdf file. I don't know how to post the whole file, so I just copied and pasted it.
   / How to choose flux core wire? #30
Reading this is good for hack welders like me. I ran out of the NR211 flux core .035" wire that came with my Lincoln 125, and had roll of the same flavor of Harbor Freight wire I had grabbed at one of their sidewalk sales so I would have roll in backup, and I think the HF wire is inferior to the Lincoln wire- lots more splatter, harder to get nice results. Maybe just me, but...
Bus (A50323)
Bus (A50323)
F-800 POWER PUMP 800 HP TRIPLEX MUD PUMP POWERED BY 3412 CAT ENGINE (A50854)
F-800 POWER PUMP...
Stainless Steel 1" Spool (A49461)
Stainless Steel 1"...
Chevrolet C8500 Flat Bed with a Moffet Kit (A51039)
Chevrolet C8500...
2014 UTILITY 53X102 DRY VAN TRAILER (A51222)
2014 UTILITY...
2022 CATERPILLAR CS44B SMOOTH DRUM ROLLER (A51242)
2022 CATERPILLAR...
