How to check and change the oil on John Deere 2305
   / How to check and change the oil on John Deere 2305 #1
maxwell18
Just purchased a 2007 JD 2305 without any paper work or manuals. I'm trying to figure out how and where to check the oil and how to change it.
   / How to check and change the oil on John Deere 2305 #3
I change the oil in my tractor with an oil extractor to get the old oil out. Then I use a little "two finger" wrench to remove the oil filter (at automotive parts stores).
About 3 or 4 years ago, I bought the oil extractor (about $30 online) from DR or others. Did a check on all the engines I routinely change oil on. Worked fine on everything except my VW Cabrio. There's some baffle in the oil pan that doesn't allow the oil extractor to go all the way down. On my 4010 tractor (similar but a little higher clearance than your 2305), there was NO OIL from the drain plug when I removed it to check. The extractor had, in effect, done a better job than opening the drain plug.
Real saver for lawn mowers or generators where there's either no drain plug or it's too low down to put anything under it.
I curse Toyota every time I have to change the oil on my Tacoma. The extractor removes the oil fine, but the oil filter is too high when you're on the ground and too low from the left fender. Screw you Toyota.
Ralph
1980 PULLMAN DRYVAN (A50854)
1980 PULLMAN...
2022 CATERPILLAR CS44B SMOOTH DRUM ROLLER (A51242)
2022 CATERPILLAR...
2005 MACK CHN613 WINCH TRUCK (INOPERABLE) (A50854)
2005 MACK CHN613...
2009 Yamaha YDRE Electric Cart (A50324)
2009 Yamaha YDRE...
3in Poly Pipe (A49461)
2012 GENIE GTH1056 TELEHANDLER (A50854)
2012 GENIE GTH1056...
