How to change or check injectors in ford 6600
   / How to change or check injectors in ford 6600 #1
derrick1115
Albertville,Alabama
MF 135
How do you check or change fuel injectors in ford 6600 tractor. Also how do you also adjust the clutch on the ford 6600 tractor
   / How to change or check injectors in ford 6600 #2
Removing injectors is pretty straight forward, unless the 6600 has some odd set up.
First remove the return lines and the injector lines. Mark the order that they come off the pump, this will prevent a major headache when you put them back on. Then pull the injectors out. The easiest way is with a slide hammer.
As for testing them you'll have to find a diesel injection shop. The one locally will bench test injectors for just a few dollars each.
2018 Autocar ACX Xpeditor T/A Hercules Front Loader Garbage Truck (A55852)
2018 Autocar ACX...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
John Deere Z320R Zero Turn Mower (A57453)
John Deere Z320R...
Honda 24hp Brush Truck Pump (A57454)
Honda 24hp Brush...
flatbed trailer 24ft (A56857)
flatbed trailer...
John Deere 204L (A56436)
John Deere 204L...
