Oil & Fuel How to change BX1800 fuel filter (underside)
   / How to change BX1800 fuel filter (underside) #1
gboehne
Does anyone have any tips on how to loosen the bolt that holds the
fuel filter bracket snugly in place - the filter that is on the underside of the tractor?
The bolt is threaded from the top and access to it is extremely limited. The lever that the bracket is mounted to also looks problematic to remove. I forgot to ask the dealer, which is what I will do if nobody can give me a tip.
Gerry
   / How to change BX1800 fuel filter (underside) #2
I used a wrench open on one end with an internal ratchet on the other. It was thin enough to slide over the bolt and the ratchet had it off in no time.
   / How to change BX1800 fuel filter (underside) #3
They are a pain to get to the first time, when I put mine back on, I flipped the loop over and put the bolt in from the bottom. Then I got a batch of bad fuel and after changing the filter a couple of more times I just started using a wire tie to hold it up.
2019 TerraGator 7300 Spinner truck (A56436)
2019 TerraGator...
2014 Lamar Trailer (A55973)
2014 Lamar Trailer...
2013 Case 580 Super N 4x4 Extendahoe Loader Backhoe (A55973)
2013 Case 580...
2006 CATERPILLAR 304C (A58214)
2006 CATERPILLAR...
2008 International 7500 T/A Altec A77T Bucket Truck (A55973)
2008 International...
2021 Freightliner Cascadia 116 T/A Day Cab Truck Tractor (A55973)
2021 Freightliner...
