How to burn stumps
   / How to burn stumps #1
MMH
Murrysville, PA
JD 4500
I have 6 to 8 stumps piled up that I have been trying to burn. After a good hot fire is lit (an alot of coals underneath the stumps), the stumps will smolder for a day or so, but will not continue to burn. The trees were cut down 6 months ago, although some of the stumps were just dug out of the ground.
   / How to burn stumps #2
If they have just been dug out, they are still wet and "green." How much dirt is left on the stumps ?? Move them around a bit to knock off as much dirt as possible to help them dry out and burn better. Good luck.
   / How to burn stumps #3
Get some stump remover powder (saltpeter) and follow the directions. Burn one year later.
There is alot of dirt on them. Not so much dirt as clay. Really cannot knock the clay off w/o significant work w/ pressure washer.
I never heard of stumpremover powder - I'll look into this.
   / How to burn stumps #6
I burned a stump out with the help of an electric fan. The forced air generates wicked hot flame that will consume a stump quickly.
   / How to burn stumps #7
Many years ago we had a job to clean up tornado damage. The company who dealt with the debris dug a pit, put pipe with holes in it around the pit, pumped air through the pipe. The debris went into the pit and burned it green with the forced air helping to burn it quickly. Pretty cool setup.
   / How to burn stumps #8
6 months!! There still wet! even if there pine there still prolly to green if there Hardwood there still green definitly as there were live till dug up. Wait another 6 months minimum! then pile trash on them and reburn them. You can burn green wood but its a lot of work to boil all that water out of them! more than half the weight of those things is water. So if you have a 1500lb root ball (if there is no dirt) there is a good 600-800lbs of water still in that thing. There is a lot of heat needed to boil 500lbs+ of water!
   / How to burn stumps #9
Get your handy dandy little hand held leaf blower and turn it on the base of the fire and it will get so hot you will have to move!
The heat removers the moisture, I guess.
   / How to burn stumps #10
++++1!! This is exactly how I get those big damp piles to burn.. its amazing how fast you can get the fire going again the next day too..
2022 RK25 PERFORMANCE SERIES TRACTOR (A54756)
2022 RK25...
2022 Ford F350 XL Service Body (A47477)
2022 Ford F350 XL...
2008 KALMER 4X2 SPOTTER TRUCK (A51247)
2008 KALMER 4X2...
2000 Trail King TK70SA-48.2 T/A 43 Ton Hydraulic Slide Axle Step Deck Trailer (A52377)
2000 Trail King...
2015 Toyota Prius (A55758)
2015 Toyota Prius...
2010 Hyundai Elantra Touring Sedan (A55853)
2010 Hyundai...
