How to Build a Berm
   / How to Build a Berm #1
bigtiller
Super Member
central Iowa
John Deere 2720 John Deere 3039R John Deere Z545R
I would like to build a berm for loading & unloading pickup trucks. I would put it on one edge of my parking area. Anywhere from 4 to 6 feet wide and about 30 inches tall.
Any ideas out there about materials to use, easy to build and maintain? It will be seen from the road so it has to be more than just a pile of dirt.
   / How to Build a Berm #2
You might be able to make it less obvious if you split the rise. Fifteen inches down and 15 inches up.
Bruce
   / How to Build a Berm #3
When I worked landscaping years ago, we built retaining walls with bricks designed to hold back weight. If you used those it would be astatically appealing, as well as, have a function. I remembered that they weighed about 75 pounds and I put 375 on one wall I built. I picked every one of those things up 3 or 4 times. When I went back to college the next year everyone was amazed at how much time I spent in the gym. I told them, I just work in the summer so I have money when I'm at school. If you dig lower so the wall isn't so high, you might have water retention problems and it will be easier to unload the pickups if the beds are level.
   / How to Build a Berm #4
I would set 1-2 "mafia blocks" (2'x2'x4' or 2'x2'x6' concrete block that the cement places make from what's left in the truck when it comes back), then get a couple of the caps that they make to go on top (otherwise, the top has a ridge to help when stacking them) and fill behind it with gravel.
Aaron Z
   / How to Build a Berm #5
Mafia Blocks:
Aaron Z
Aaron Z
That is one of my ideas also. So I called the 2 closest ready mix plants and neither of them deliver or set them and one of them kinda chuckled at the idea of setting them. So I thought I would build my own, which lead to the idea of making it out of lumber or timbers or blocks. And all that brought me here with the question thinking maybe someone has built one and has some tips or tricks for building & maintenance success without spending all my pocket money.
I think I'll call some ready-mix plants further away in the big town.
   / How to Build a Berm #7
You might try a place that sells cement septic tanks as they are usually equipped to do that. If not, I would find a local excavation contractor and have them deliver/set them. At 3000# for a 6' one, they aren't light, but they shouldn't be a huge deal.
Aaron Z
   / How to Build a Berm #8
Sometimes you can find used RR ties for sale.
Stack them and stake them with re-bar and back fill.
would you offset them any (how much) or stack them straight up?
   / How to Build a Berm #10
At 3000# for a 6' one, they aren't light, but they shouldn't be a huge deal. Aaron Z
They advertise them around here... delivery with a minimum purchase. But I wanted to move them myself and the lightest they have are 2,000 lbs. My poor CK27 can't lift that much.
I'm amazed the OP found resistance at the supplier. What else are they going to do with them except make retaining walls? :confused:
2017 PETERBILT 579 DAYCAB (A55745)
2017 PETERBILT 579...
2020 Kubota RTV-X1100CW-A (A47384)
2020 Kubota...
2008 PETERBILT 367 FLAT TOP SLEEPER (INOPERABLE) (A55745)
2008 PETERBILT 367...
2005 Isuzu NPR Venco VC516 Landscape Dump Truck (A55788)
2005 Isuzu NPR...
2012 Volkswagen Jetta Sedan (A53424)
2012 Volkswagen...
flooring (A55758)
flooring (A55758)
