Bentrim
- Joined
- Apr 22, 2020
- Messages
- 319
- Location
- York County, Pennsylvania
- Tractor
- Massey Ferguson 245, Massey Ferguson 14 Allis Chalmers G
Let me see if I can throw a few monkey wrenches in the mix.
Air can only enter a system on the suction side. As mentioned many times before, check the supply side if you suspect air in the system.
Air in the system is indicated by a bouncy loader. In other words the frame of the loader will bounce up and down when the tractor is driven over a rough place.
An open center system does not need bled, only cycled a time or two.
Control valves can have issues but usually cause few problems, One problem that can happen is the centering spring retaining screw comes loose and does not center the valve spool. This can cause unusual, unexpected movement. Are the ends of both spools equal? Does the spool/lever seem to have too much free travel? If you move valve spool by hand slightly does control improve? Load checks are valves that hold the loader until system pressure exceeds the load. without them when you raise the loader it would drop slightly before starting to raise. There are no O rings that seal inside a valve. The O rings only seal the oil in the valve and keep it from leaking on your shoe.
Pumps only draw oil (and air if available) from the reservoir and move it to discharge port, thru a hose to the valve, from the valve it returns to the reservoir, or to a work port if activated.
Valves can usually be repaired if centering springs break, the centering spring bolt comes loose, or they leak. Valves housings and spools are usually matched or fitted and spools cannot be interchanged or replaced. The only way a valve needs replaced is if it is cracked or damaged.
Double acting cylinders CAN a do leak past the piston. There will be no sign of a leak as oil is only changing sides within the cylinder. How to find out. Listen to the cylinder with a stethoscope or a pipe if leaking you will hear the oil bypassing the piston
From your complaint I would check for a suction leak, check for a loose centering spring and or the cylinder packing.
Good luck I hope it is an easy cheap repair
