How to align an 18" pin for the plow blade
   / How to align an 18" pin for the plow blade #1
chrisott
Kubota BX24
Well it seems I forget what's under the snow and hit a few things with my 60inch hydraulic plow blade (BX2763A) plowing over to the wood pile. I have a replacement blade pin, but how do I align the hole in the pin with the hole in the plow blade so I can put a bolt in it? I remember the pin slid right into the blade and hitch when new and I could turn the pin with a screwdriver to then slip the bolt through, but I think everything is banged up a bit after 4 winters. I had to tap the pin in and now I can't align the holes to drop the bolt through. I would really appreciate some suggestions from the forum folk.
Thanks.
Chris
   / How to align an 18" pin for the plow blade #2
Thanks.
Chris
What machine is this on?...not familiar with the attacment model numbers.
What happened to the original pin? If it's similar to the one I had that's like an inch thick.
   / How to align an 18" pin for the plow blade #3
Make one!
Get a same diameter rod or bolt (with head cut off) and taper grind it to a bullet shape.
Drive the 'bullet' in with firm taps or blows and once in place tap your bolt in all while it pushes out your 'bullet'.
(Then put the bullet in your tractor tool box for next time LOL)
timswi,
I did not tell the whole story, I guess. The original bolt (1/4 inch) must have fallen out and the pin worked its way loose such that when I hit something under the snow (a stump I think) the pin bent. It is 3/4 inch thick. The plow is a Kubota hydraulic plow sitting on the Kubota quick hitch and subframe which is on a Kubota BX24.
Piloon,
That's a good tip. I was trying to do that with a screwdriver, but it is not tapered and has too big a head for the working room. I'll try this tonight before the next snow storm. (tomorrow)
Piloon,
On my way to make the bullet I notiiced an old nail punch in a drawer with files. This did the trick. I tapped and aligned from the bottom and put the bolt in through the top.
Thanks.
2014 Ford Explorer SUV (A56859)
2014 Ford Explorer...
2007 Honda CR-V SUV (A56859)
2007 Honda CR-V...
2017 Ford T350 van (A55973)
2017 Ford T350 van...
2022 Brush Wolf 7800-HF Skid Steer Brush Cutter (A55315)
2022 Brush Wolf...
(APPROX 15) 2" X 6" X 20'- 3/8" THICK METAL TUBING (A54757)
(APPROX 15) 2" X...
2015 Ford Taurus AWD Sedan (A54815)
2015 Ford Taurus...
