How to adjust rate of descent valve?
   / How to adjust rate of descent valve? #1
Nazrat
The 3pt hitch on my MT372 lowers FAST. It just drops the equipment. I turned the control knob under the seat clockwise to the stop and it didn't change. I tried to adjust the bolt in the center but no luck. Do I need to replace the O-Rings on it?
Thanks,
Tad
   / How to adjust rate of descent valve? #2
Mine did that when I bought it. Turns out there was a spring broken in the lift cylinder.
You have to pull the "head" from the lift cylinder and look inside. I used a spring that I had that looked like it would fit and it has worked for 10 years now.
Do you have a manual?
It was a very eazy fix with the manual.
There is a small spring and ball that restricts the oil flow and regulates the speed of the drop.
Thanks. I found the mangled spring just before you posted that. It also had a chewed up c-clip. The clip, spring and ball had fallen down into the piston and been smashed a few hundred times. The ball survived, denting the top of the piston a little but the spring/clip were gone. I ended up having to grind down a 5/8" internal c-clip to fit because I couldn't find anything in between that and 9/16" which was too small.
Thanks for the help!
-Tad
UNUSED Heavy Duty Ratchet Strap Set (A53117)
UNUSED Heavy Duty...
2017 Ford Explorer AWD SUV (A54815)
2017 Ford Explorer...
2012 JOHN DEERE 160G LC EXCAVATOR (A52705)
2012 JOHN DEERE...
2005 JLG 660SJ TELESCOPIC MANLIFT (A52705)
2005 JLG 660SJ...
2016 FREIGHTLINER M2 106 26' BOX TRUCK (A54313)
2016 FREIGHTLINER...
UNUSED RAYTREE RMPP680 HYD POST POUNDER (A54757)
UNUSED RAYTREE...
