How to adjust hydraulic pressure on a ck2510
   / How to adjust hydraulic pressure on a ck2510 #1
Everhard
Mulmur, Ontario
Kioti Ck2510
So I finally got around to hooking up a gauge to my ck2510 and checked the hydraulic pressure, it's maxed at 2100psi.
So... The question - how to adjust it to get it closer to what the max can\should be which I believe is +-2500psi.
I know on other models the pressure relief is located at block where the rear remotes are located, wondering if that's the case for my tractor, if anyone has any further info.. Be much appreciated. Thanks!
E.
   / How to adjust hydraulic pressure on a ck2510 #2
Where did you measured the pressure? What pressure are you trying to increase? Loader? Remotes? Also, what does the manual say regarding the pressure?
Each valve (Loader, remotes, 3pt) will have it's own relief valve. The first valve in the circuit (usually the loader one) dictates the system pressure for the rest of the hydraulic circuit. Which means increasing the relief pressure on the valves further down the line, won't have any effect at all as it's still limited by the first valve in the circuit.
Sometimes there is an hydraulic block after the pump where the loader valve connects too. That will be the first relief valve in the circuit, therefore the main one. I don't know if that's the case on your CK2510.
Anyway, keep in mind that it's very easy to blow up things by playing with relief valves. Definitely have your gauge there, monitor the pressure and don't go over the max pressure said on the manual.
   / How to adjust hydraulic pressure on a ck2510 #3
I would search YouTube for an instructive video.
1999 GENIE S-60 TELESCOPIC MANLIFT (A51242)
1999 GENIE S-60...
2015 CASE 850M WT CRAWLER DOZER (A51242)
2015 CASE 850M WT...
Portable Calf Creep Feeder (A50515)
Portable Calf...
Kubota SVL95-2s (A50120)
Kubota SVL95-2s...
2012 Ford F-450 Altec AT200A 30FT Bucket Truck (A50323)
2012 Ford F-450...
UNUSED AGT QUICK ATTACH AUGER SET (A51244)
UNUSED AGT QUICK...
