3-Point Hitch How to add remotes/power beyond to Ford 1920?
   / How to add remotes/power beyond to Ford 1920? #11
Not to further muddle things here but if you've bought the adapter plate why not just use it? In my mind that's the cleanest and easiest not to mention fool-proof way to do what you want. you can hook any spool you want up to it. (assuming the spool is set up with power beyond)
Just match up 3 hoses from the spool to those 3 ports and you're done. I just added a 3spool to my tractor, wish I had an adapter plate option! In the end my solution ended up being simple enough happily.
Yes you could hook into the hydraulic system where the loader valve is but that will take a lot more work and likely more cost.
E.
2020  FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A52576)
2020 FREIGHTLINER...
2022 BOBCAT S740 SKID STEER (A52707)
2022 BOBCAT S740...
2012 Case IH 1250 24-Row Early Riser Planter (A53485)
2012 Case IH 1250...
UNUSED FUTURE 750 REMOTE CONTROLLER LAWN MOWER (A57193)
UNUSED FUTURE 750...
2023 54' Hooklift Dumpster 20 Cubic Yard (A53422)
2023 54' Hooklift...
1535 (A57192)
1535 (A57192)
