How to add a pressure gauge to a 2615/2816 etc ??
   / How to add a pressure gauge to a 2615/2816 etc ?? #1
Wyld Bill
Central Maine
Mahindra
So I've wanted to do this for a while, add a pressure gauge to the outlet side of my hydraulic system to monitor system pressure & see if I am work to the full recommended pressure. I don't want to tap in somewhere that only reads pressure when your doing a certain thing. I want to tap in at point where no matter what I put for a hyraulic load on the tractor, I am reading that pressure. So I guess it would be th eoutlet side of the pump. If there is a place on the loader vlave that I could tee in to plumb somthing in perminently that would be great. Thanks.
   / How to add a pressure gauge to a 2615/2816 etc ?? #2
T into the pressure line going to the loader valve, but the only time it will read full pressure is when you put the system under load and the relief valve opens. It is a open center system and unless you are using some of the hydraulics, the pump just pumps oil back to the reservoir with not much resistance to build pressure.
2017 Ford F-150 Pickup Truck (A50323)
2017 Ford F-150...
Agco 4210 3pt 2 Star Tedder (A50774)
Agco 4210 3pt 2...
2013 FREIGHTLINER CASCADIA 125 DAY CAB (A52141)
2013 FREIGHTLINER...
Club Car Electric Utility Cart (A51694)
Club Car Electric...
2008 Saturn VUE SUV (A50324)
2008 Saturn VUE...
2010 International 4400 National Crane 300C 56FT 8 Ton Crane Truck (A50323)
2010 International...
