How to add a pressure gauge to a 2615/2816 etc ??
   / How to add a pressure gauge to a 2615/2816 etc ?? #1
Wyld Bill
Central Maine
Mahindra
So I've wanted to do this for a while, add a pressure gauge to the outlet side of my hydraulic system to monitor system pressure & see if I am work to the full recommended pressure. I don't want to tap in somewhere that only reads pressure when your doing a certain thing. I want to tap in at point where no matter what I put for a hyraulic load on the tractor, I am reading that pressure. So I guess it would be th eoutlet side of the pump. If there is a place on the loader vlave that I could tee in to plumb somthing in perminently that would be great. Thanks.
   / How to add a pressure gauge to a 2615/2816 etc ?? #2
T into the pressure line going to the loader valve, but the only time it will read full pressure is when you put the system under load and the relief valve opens. It is a open center system and unless you are using some of the hydraulics, the pump just pumps oil back to the reservoir with not much resistance to build pressure.
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
7021 (A50322)
7021 (A50322)
2008 Isuzu NPR-HD Landscape Dump Truck (A50323)
2008 Isuzu NPR-HD...
2013 JLG G9-43A Telehandler (RUNS) (SMOKES) (A50774)
2013 JLG G9-43A...
Caterpillar 345D Hydraulic Excavator (A50322)
Caterpillar 345D...
1996 JCB TELEHANDLER (A50322)
1996 JCB...
