How tight a curve is ok on hydraulic line?
   / How tight a curve is ok on hydraulic line? #1
Deepdrop
Lebanon, New Hampshire
Kioti CX2510 (2021)
I've been trying to find out if my hydraulic lines are running too tight a curve. I can't find any guidance online that I can understand, but i sure don't want them to be at risk of rupture. I'm attaching pictures if that is helpful, but would appreciate it if anyone has advice on this. Thanks.
   / How tight a curve is ok on hydraulic line? #2
That one hose looks a little short but I don't think it will cause any issues. :thumbsup:
   / How tight a curve is ok on hydraulic line? #3
All hose (at least the decent stuff) has a published minimum bend radius.
I would say that bend is too tight of radius. Adding a 45 or 90 deg JIC Adapter might reduce the bend enough with out replacing the hose.
652 | JIC 37deg Swivel Nut 45deg
   / How tight a curve is ok on hydraulic line? #4
I would put a 45deg or 90 deg swivel adap;tor on that hose. Pressure fluctuations will put pressure on the clamping edge hose area. Cheap insurance.
   / How tight a curve is ok on hydraulic line? #5
Completely, 1000% uneducated, unprofessionally trained opinion ... too tight. Add a 45 as suggested. If that's as new as it looks, maybe have the dealer do it as a warranty item.
   / How tight a curve is ok on hydraulic line? #7
Go to any site that is a supplier of hydraulic hoses and with the knowledge of what your hose is compare it to suppliers hose and its specifications for bends...
I agree with others...Looks a little tight...
Dale
Thank you all. It looked too tight to me. I hate being in the position of having to keep asking my dealer to fix things on a brand new tractor.
   / How tight a curve is ok on hydraulic line? #9
Actually things like this is something that dealer should have never let tractor off his lot with something like that.... Keep going back till dealer gets it right....
Dale
   / How tight a curve is ok on hydraulic line? #10
I’d put 2 45s in it and it would be a lot better.
UNUSED CFG H15R EXCAVATOR (A51247)
UNUSED CFG H15R...
(4) STEEL CARTS W/ WHEELS (A51248)
(4) STEEL CARTS W/...
(2) METAL SPOOLS W/ SOME DURALINE 4" PVC PIPE (A51248)
(2) METAL SPOOLS...
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
UNUSED CFG QK18R EXCAVATOR (A51247)
UNUSED CFG QK18R...
2021 HAMM HD+9I VO DOUBLE DRUM ROLLER (A51246)
2021 HAMM HD+9I VO...
