How thorough should I sandblast old rust/paint before applying POR15/primer?
   / How thorough should I sandblast old rust/paint before applying POR15/primer? #11
:laughing::laughing::laughing:
Am I just blind!
I should have said, "am I just stupid"....that way you could have simply replied...
YES! :laughing:
EDIT: Pclausen, you just inspired me to update my avatar pic :)
Appreciate all the advice! I'll pick up some epoxy primer and take back the tsc primer. I haven't mentioned or shown it in any pics, but there is a significant built up of rust in the cavities on the center mount portion of the blade section. Same goes for the pivot assembly. The previous owner had the blade sitting outside and water would get trapped there I plan to use the POR15 stuff in these areas. I also have a 1970's era John Deere 45 3-16 plow that is very rusted that I'll be using the POR15 on.
Thanks for the comments about my avatar. That's Rufus. Here he is with his sister (Toska) back when he was just a pup.
All grown up checking out the cat.
And a couple of just Rufus.
His 11th birthday is coming up, but he's still as playful as when he was a pup!
   / How thorough should I sandblast old rust/paint before applying POR15/primer? #14
Great pics of Rufus! :thumbsup:
   / How thorough should I sandblast old rust/paint before applying POR15/primer? #15
I'm glas to hear you are going to do itt right, with epoxy. Now, what most people would do is they would go to their local auto paint store and ask for epoxy. Then when they find out how much name brand epoxy costs, they end up getting off brand stuff like Omni (made by PPG) or Nason (Dupont). Logic would tell you that it is relabled,and just as good. WRONG! Do yourself a favor and order some Southern Polyurethanes Epoxy. It is the best at ANY price, and you will probably save money vs most of the off brands. Just make sure to print out a tech sheet and follow it. Temperature is everything when it comes to curing epoxy.
   / How thorough should I sandblast old rust/paint before applying POR15/primer? #16
The POR-15 works really well, but you MUST follow the instructions exactly for topcoating. The POR paint must be topcoated or primed while it's still tacky. If not, your top coat will come off in sheets as it won't bite into the POR-15 to achieve adhesion.
If you get it completely clean, and are sure no rust is present, go with anything you like. The epoxy will work better than just automotive paint. If you have a chance of rust left in pits and the like, you can't beat the POR-15. JMHO
   / How thorough should I sandblast old rust/paint before applying POR15/primer? #17
I have used a good bit of the TSC stuff it works real well from what I can tell, look here I did a NEW build Dump Trailer in 01/02 era and it is still pretty good only spots rusty now are where large gravel or FEL have scrapped it up. I probably would not use POR on the Blade as it is somewhat SOFT and also not UV resistant. Use some good Phosphoric Acid to eat up the rust or if you have a good charger dip & use a electrolytic rust remover (electrically removes rust using welder/charge a soda solution of water and a day or two of electricity.) Been there done that on some top links that rusted up. search TBN for removing rust with electricity or maybe rust and washing detergent there are a few real good threads on how to do it.
album 9 pics dump trailer pictures by WPSPIKER - Photobucket
getting paint to stick is pretty much 95% surface prep and 4% paint mixing and 1% technique. I have been to PPG classes for surface prep work & how to use products correctly in the past. I built a lot of Power and Liquid painting systems booths ovens ect for may years.
The one thing to remember with Enamels is to add correct amount of Catalyses/hardners into the mix and only mix what you need to do the job at the time of the job is going on. Mix one spray cup full at time or if you are going to roll/brush just enough for job at hand. Thin first coat is best with a good tack time (not overly dry) than a medium second coat.
Yes Imron is very good, and it is from the 80s too, I painted imron on cars back then (probably painted over 100 cars in my body shop days & lots of equipment since then) the TSC paints are almost as good for durability which for implements is what you need high gloss on a PLOW or BLADE is well getting a bit anally challenged ;) hahah (j/k) Remember if you are using these things paint is going to be scratched damaged and or worn off do yourself a favor and try to keep stuff working well first and looking good 2nd...
as far as Hyd Cylinders and Sand Blasting grit, yes the blast media can damage the chrome rod which can cut seals and cause fluid leakage.. The cylinder in the dump cart is damaged prior to me getting it for free. it is PUSH only and each full up stroke spits hyd fluid out due to sand blast damage it was a transport disk cylinder if I remember right that owner had blasted the plow by a young kid. it still works but leaks about 1/4 cup per lift when it is full. BTW use some Vaseline or grease to coat the cylinder Rod prior to painting in this pic.
Mark
Ok, so based on what you guys are saying, here's my plan:
1. Continue sandblasting to get as close to bare metal as possible everywhere.
2. In cavities and such where I can't get all the rust out, use POR15 (following the POR15 directions), and apply a top coat of Imron burnt orange while to POR15 is still tacky.
3. Apply Southern Polyurethanes Epoxy Primer (gray) to all the remaining bare metal after prep (dry sanding with 80 grit).
4. Apply coat of Imron burnt orange within 7 days of laying down the epoxy primer, feathering onto the areas with POR15/Imron.
Does that sound like a good plan? Oh, and I'll wait until it gets into the 70s before applying anything. My shop is heated, but I don't want the mess inside. Besides, I can't have heat and be well ventilated at the same time when the outside temps are low.
p.s. Mark that dump trailer looks great!
One other question. On the surfaces that slide against each other when changing the angle of the blade, should I just leave them alone and apply some grease during re-assembly, or give them the full treatment as well (epoxy primer, then Imron)?
The surfaces I'm talking about are marked with red lines in the image below:
Thanks!
   / How thorough should I sandblast old rust/paint before applying POR15/primer? #20
with those sliding/rotating sections do not put any POR on there. again POR is a softer base designed to seal up rust and cause it to stop active rusting. Those sections should have very little paint more paint will only cause binding and scrape loose to roll up more.
again get some good phosphoric acid to remove rust especially in those areas. after setting kept wet with it the rust will be mostly gone and a bluish tint (looks a bit like oil on water) colored to indicate the acid has etched the area well. then no primer is needed just a two LIGHT coats of paint one light wet coat and a second wet coat from sprayer to keep thickness of paint low there. dont really need any grease there as grease will tend to hold dirt and or grime and cause more binding.
if it is pitted bad (does not appear to be) you could sand paint smooth and put a 2nd paint coating on after 1st dried. the paint on paint should slip and rotate easily enough just be sure to use a hardner in the paint.
mark
2016 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2016 Ford F-150...
1992 Norris Long Basket Trailer (A55973)
1992 Norris Long...
2016 Lincoln Navigator SUV (A59231)
2016 Lincoln...
2021 Billy Goat F902H Walk-Behind Debris Blower (A59228)
2021 Billy Goat...
1453 (A57192)
1453 (A57192)
Landoll 7130 Harrow (A59814)
Landoll 7130...
