How thick are hollow core doors?
   / How thick are hollow core doors? #1
dodge man
Super Star Member
West central Illinois
JD 2025R
We are doing some remodeling and had new flooring installed. They just put new underlayment down and the new plank flooring. We have a set of bi fold door that are now to tall. They have spring loaded pegs and rollers on the top that are compressed all the way. I want to cut some off the bottom and then reinstall the peg on the bottom that is the pivot. I need to cut off a little more than a 1/4 inch from the bottom. Will that expose the hollow part of the door?
   / How thick are hollow core doors? #2
You should be ok cutting 1/4” off. Generally the cheapie bifold doors have 1-1/2” top and bottom stiles. You could confirm by pulling out the spring loaded pegs and checking the depth of the hole with a piece of wire with a short 90 bend at the end.
   / How thick are hollow core doors? #5
I've had to cut several where that left no filler at the bottom and I simply glued in a new piece. Left a clamp on overnight.
Done the same thing. Works good
2008 Ford F-150 XL Pickup Truck (A53117)
2008 Ford F-150 XL...
CRESCENT  MANIFOLD TRAILER (A53843)
CRESCENT MANIFOLD...
2018 Mercury Verado 250HP Outboard Boat Motor (A51694)
2018 Mercury...
2021 International HV507 4x4 12ft Single Axle Dump Truck (A54814)
2021 International...
4 ft Plastic Feeder Trough (A53117)
4 ft Plastic...
2006 MACK GRANITE CV713 DUMP TRUCK (A51406)
2006 MACK GRANITE...
