How thick are hollow core doors?
   / How thick are hollow core doors? #1
dodge man
Super Star Member
West central Illinois
JD 2025R
We are doing some remodeling and had new flooring installed. They just put new underlayment down and the new plank flooring. We have a set of bi fold door that are now to tall. They have spring loaded pegs and rollers on the top that are compressed all the way. I want to cut some off the bottom and then reinstall the peg on the bottom that is the pivot. I need to cut off a little more than a 1/4 inch from the bottom. Will that expose the hollow part of the door?
   / How thick are hollow core doors? #2
You should be ok cutting 1/4” off. Generally the cheapie bifold doors have 1-1/2” top and bottom stiles. You could confirm by pulling out the spring loaded pegs and checking the depth of the hole with a piece of wire with a short 90 bend at the end.
   / How thick are hollow core doors? #5
I've had to cut several where that left no filler at the bottom and I simply glued in a new piece. Left a clamp on overnight.
Done the same thing. Works good
2012 Nissan Rogue (A50324)
2012 Nissan Rogue...
FUEL TANK/TOOLBOX COMBO (A53843)
FUEL TANK/TOOLBOX...
Kohler Transfer Switch & Generac 200A Transfer Swi (A53117)
Kohler Transfer...
2006 Kobelco SK210LC Hydraulic Excavator (A52377)
2006 Kobelco...
2014 Chevrolet Tahoe SUV (A52377)
2014 Chevrolet...
BUSH WACKER ST-180 ELITE BATWING ROTARY MOWER (A51406)
BUSH WACKER ST-180...
