How the heck do you guys torque a cylinder nut to 600 ft lb? Rebuilding Bobcat combo bucket cylinder.
   / How the heck do you guys torque a cylinder nut to 600 ft lb? Rebuilding Bobcat combo bucket cylinder. #1
clydesdale
Bronze Member
I am putting new seals in and apparently I need to get the bottom nut to 600 ft lb. I do not have that kind of torque wrench. How do most people achieve this? Thanks.
   / How the heck do you guys torque a cylinder nut to 600 ft lb? Rebuilding Bobcat combo bucket cylinder. #2
Look up "torque multiplier". The question is the accuracy of these things. You can spend a lot or a "little".
   / How the heck do you guys torque a cylinder nut to 600 ft lb? Rebuilding Bobcat combo bucket cylinder. #3
Ditto on torque multiplier
   / How the heck do you guys torque a cylinder nut to 600 ft lb? Rebuilding Bobcat combo bucket cylinder. #5
Torque multipliers use a fixed gear ratio. It's not going to get "out of calibration" or be "inaccurate ". Output will always be the same multiple of the input.
Garbage in, garbage out. (Potentially) If your 1/2" drive torque wrench is off by 1 lb/ft your finish torque using a 64:1 multiplier will be off by 64 lbs/ft. I'll stick to a cheater bar and my sense of feel.
   / How the heck do you guys torque a cylinder nut to 600 ft lb? Rebuilding Bobcat combo bucket cylinder. #6
What does "bottom nut" actually look like.... May determine on approach to achieving 600 ft-lbs....
   / How the heck do you guys torque a cylinder nut to 600 ft lb? Rebuilding Bobcat combo bucket cylinder. #8
Do we want to open the discussion on lubricated vs non lubricated surfaces and threads? 🤣
   / How the heck do you guys torque a cylinder nut to 600 ft lb? Rebuilding Bobcat combo bucket cylinder. #9
NO!!! We could also avoid a discussion about the anality of absolute torque values.
   / How the heck do you guys torque a cylinder nut to 600 ft lb? Rebuilding Bobcat combo bucket cylinder. #10
Heck I'm getting older and more tired, a six ft piece of pipe and 100 pound pull is the easy way out.
KISS
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A52577)
2019 INTERNATIONAL...
NEW Woods 6ft Finish Mower (A53472)
NEW Woods 6ft...
2007 VOLVO VHD64 TRI AXLE DUMP TRUCK (A53426)
2007 VOLVO VHD64...
UNUSED RAYTREE RMDM70-70" HD DISC MULCHER (A51248)
UNUSED RAYTREE...
2007 CATERPILLAR D5GXL CRAWLER DOZER (A51406)
2007 CATERPILLAR...
UNUSED FUTURE FR70 69" LEVELER (A51248)
UNUSED FUTURE FR70...
