How sturdy IS the PT adapter plate?
   / How sturdy IS the PT adapter plate? #11
I used my bare plate to move farm equipment and eventually the two rods the are "welded" through the plate both came loose. My local welding shop fixed it for $15.00 and made it much stronger than the original weld. I have continued to move equipment since with no issues.........
   / How sturdy IS the PT adapter plate? #12
Welcome to TBN, and The PT forum. We all like good pictures. Please share if you have them. We also like to hear how you are using your machine, good or bad, so that others might learn.
What part of the country do you live.
   / How sturdy IS the PT adapter plate? #13
Welcome to TBN and the PT family. What model do you have?
PJ
   / How sturdy IS the PT adapter plate? #14
<font color="red"> "oem" stands for "There MUST be a better way!!!!" </font>
or RFI /forums/images/graemlins/grin.gif
   / How sturdy IS the PT adapter plate? #15
I pushed the bare plate against a tree and bent it enough to make it difficult to put on attachements. I had to straighten it out. I never push anything with just the plate now.
Bob Rip
   / How sturdy IS the PT adapter plate? #16
You are very correct, last winter with about 1500 hrs the rod went. First just a slight crack but by the end of the day continuing to do our snowplowing work the road needed to be replaced!
   / How sturdy IS the PT adapter plate? #17
is the rod inside one piece or two?if it's two pieces that would be the reason for the failures.
   / How sturdy IS the PT adapter plate? #18
If you are talking about the pivot pin., it is one piece. I had to replace the rod and toggle assembly on my PT-1445. The two parts froze together. I could not separate them with a 20 ton press.
2005 Winnebago Sightseer 30B 30ft. Class A Motorhome (A55853)
2005 Winnebago...
MARATHON 76KW GENERATOR (A55745)
MARATHON 76KW...
2018 Generac S/A Towable Light Tower (A55973)
2018 Generac S/A...
Pig Statue (A55853)
Pig Statue (A55853)
2005 EAST 45' WALKING FLOOR TRAILER (A54756)
2005 EAST 45'...
2021 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A56858)
2021 Chevrolet...
