Mowing How sharp do mower blades have to be...really.
   / How sharp do mower blades have to be...really. #1
johann
bx2200
I know it sounds basic, but how sharp do mower blades need to be? I have done them as if I was sharpening an axe. I was recently discussing with my brother, and he finishes his off with a squared leading edge, not much, mabe 1/16th of an inch flattened on the cutting edge. I know they need to be balanced but is a sharp point a waste of time?
   / How sharp do mower blades have to be...really. #2
i sharpen mine like i would a splitting maul ( 25 degree bevel ) . sharp but not pocket knife sharp ( 15 degree bevel ) . i use a 4 inch angle grinder for the bevel and file the flat side of the blade to finish the edge .
   / How sharp do mower blades have to be...really. #3
Not only is a very sharp edge wasting your time, a very sharp edge will dull quickly and such an edge will injure the blade when it encounters objects.Not quite as blunt as 1/16", but a little bit. Try to duplicate the factory edge, if possible.
   / How sharp do mower blades have to be...really. #4
I sharpen mine razor sharp. Shave hair they will. Let the grass put the 1/16" flat on the blades if the blades do need it. The edge needs to be strong. Work the burr off both sides of the blade with a file. No different than a knife. It's something that needs to cut well. Something with a 1/16" flat on the edge won't cut as well with something with a razor edge. Try a 1/16" flat edge on a tomato.
   / How sharp do mower blades have to be...really. #5
Oh boy- this is gonna open a can of worms with various answers.
For me, If I cut regularly when its 1/3 of cutting hieght or less, I find it works better with a sharper edge, but it wears out faster. I usually would need to resharpen every 2 weeks or so. If I let the grass grow taller before cutting, say a few inches of cutting height, a blade with a slight flat edge seems to cut better and last longer. I no longer wait that long anymore, so I use the 1/3 rule and resharpen often. Lawn seems to look better that way.
   / How sharp do mower blades have to be...really. #6
Surely this depends on the work being done. My mowing is strictly slashing weeds and branches. Obviously razor sharp is a waste of time. If you are mowing a lawn then sharp can be justified.
Weedpharma
   / How sharp do mower blades have to be...really. #7
The Gearmore/King Kutter manual recommends a 1/16" flat on the leading edge, and has a line drawing of the cross section of a properly sharpened blade showing this.
http://www.gearmore.com/partsbooks/L60_L72RotMwrBook.pdf
I was just searching this yesterday. Now I need to find a way to keep lynch pins on this thing.
   / How sharp do mower blades have to be...really. #8
A very sharp edge dulls immediately when used, so it is questionable if you need to go to the bother of sharpening to a razor edge... look at the edge on a brand new blade, and you will find it isn't razor sharp. The angle of sharpening is important... generally the width of the slope should be twice the thickness of the blade. For example, if your blade is 1/8" thick, then the width of the sharpened slope should be 1/4". This is a good rule of thumb which will give you the correct angle.
   / How sharp do mower blades have to be...really. #9
I sharpen my MMM like they come when new which is sharp, but not super sharp and my rotary cutter blades as per manual which is not sharp.
I can make it through almost a whole mowing season without having to resharpen, so you can get a good cut without knife "sharp" blades.
Zero Turn Mower (A55853)
Zero Turn Mower...
(INOP) 2015 FORD F-250XL SUPER DUTY TRUCK (A57192)
(INOP) 2015 FORD...
(APPROX.52) UNUSED 2X4X16 PRIME GRADE LUMBER (A57192)
(APPROX.52) UNUSED...
2016 Ford Explorer AWD SUV (A55853)
2016 Ford Explorer...
(UNUSED) PROTECTA PRO-LINE (A57192)
(UNUSED) PROTECTA...
SULLIVAN PATEK AIR COMPRESSOR (A58214)
SULLIVAN PATEK AIR...
