How reliable is Kioti e.g. compared with Kabota?
   / How reliable is Kioti e.g. compared with Kabota? #51
And I have to ask WHY you decided on the DK35? In all honesty, If I was to buy another tractor, it would be a DK40 or DK45. Not much bigger and I dont think much more $$$ than the 35, but stronger loader:
I have to agree with that...not that the 35 is a slouch..Mike.
   / How reliable is Kioti e.g. compared with Kabota? #52
Two reasons, one more important than the other.. first reason, the money, but I could have overcame that. Second and most important reason, is my wife had trouble getting on and off of the DK40se. It is just enough higher she had difficulty. She has had many back surgery's and has a more limited range of motion. And she does need to drive the tractor at times. She had no trouble getting on the DK35se. The smaller tires/wheels seemed to make the difference.. Yes the loader is not near as much as the DK40se, but it is better than the L3400HST. And no I cannot keep the L3400HST, it bought the way back into the DK. It may be here by the end of this week.
James K0UA
   / How reliable is Kioti e.g. compared with Kabota? #53
"Two reasons, one more important than the other...."
Hey, it's great to see you are getting a new machine, and even better that you are considering all operators' needs.
Enjoy your new tractor..there's always a "could've, should've", but this one is new and it's yours.
Jon
   / How reliable is Kioti e.g. compared with Kabota? #54
James K0UA
Also for some loader operations the weight of the tractor is more important than the pin rating at full height. Pushing the bucket into virgin soil for example. Also I read somewhere too, that the breakout force on the 35 loader isn't as far off the 40/45/50 loader either, I guess the 35's loader geometry favours breakout force more than the force at max height which makes more sense on a CUT too.
I know I automatically dismissed the 35 when I was buying but after reading a bit more about it, probably I could do everything I've done so far with the 35 instead of the 40, just with a few more trips with a slightly smaller bucket. I'm sure you'll enjoy the tractor!
   / How reliable is Kioti e.g. compared with Kabota? #55
Thanks for the info, I will be comparing it to the L3400hst to see what I think. I am keeping my "beater bucket" the one I converted to SSQA on the L3400 for a knock around digging bucket. I will use the 66 inch OEM Kioti bucket for material handling. Smartest move I ever made was keeping the original pin on bucket and converting it. I like having the 2 buckets and they only wanted to give $100 for it in trade, and I spent 124 for the plate, and maybe 20 bucks in cutoff wheels and materials. I am pretty pumped to get the DK and try it out.. but is supposed to be raining Saturday though.:(
James K0UA
   / How reliable is Kioti e.g. compared with Kabota? #56
" Second and most important reason, is my wife had trouble getting on and off of the DK40se. It is just enough higher she had difficulty. She has had many back surgery's and has a more limited range of motion. And she does need to drive the tractor at times"
Your a good man James to be thinking of that. Also makes life easier.:laughing:
   / How reliable is Kioti e.g. compared with Kabota? #57
That for sure would have sealed the deal for me on the DK40:laughing:
   / How reliable is Kioti e.g. compared with Kabota? #58
Cub Cadet is Yanmar, Kioti is the brand name of Daedong in North America and Daedong makes tractors for Bobcat, McCormick and Landini (not sure if there are others).
Actually Cub Cadet is still transitioning. They did merge a few years back but Yanmar has their own tractor line and now all utility tractors will have the Yanmar name with their engines. My 7260 Cub Cadet is an MTD with a Mitsubishi engine. 1998. Extremely difficult to find parts for and not available from Yanmar/Cub Cadet because essentially the Cub Cadet utility tractor line does not exist anymore. Only below sub compact garden tractors and on down are now supplied as Cub Cadet/Yanmar. It can be quite confusing and constant research to keep up with all this stuff.
   / How reliable is Kioti e.g. compared with Kabota? #59
I apologize. I was summing it up. But you did not directly say "nicer"
Kioti is definatally going to be less expensive than a comparable kubota with similar features. It is just the way things work. Kioti is the "new" kid on the block. They havent been around long enough to make their name as well known. Kubota was in the same boat 15 years or so ago. They HAVE to be priced less than deere, CNH, kubota, et al. or they wouldnt sell many tractors.
That is not to take anything away. They are good tractors with MANY happy customers. But along with that, they will grow, and become as well known as kubota and deere. And then you will see them all priced in the same ballpark.
I SHOPED FOR A LONG TIME FOR A TRACTOR TO USE IN THE WOODS. I RECENTLY BOUGHT A DS4110 KIOTI. I HAVEN'T HAD IT LONG ENOUGH TO FOR AN OPINION , BUT SO FAR I'M HAPPY WITH IT. HOWEVER I DO HAVE A QUESTION MAYOBE SOMEONE CAN ANSWER. THE KIOTI DID NOT COME WITH REAR HYDRAULIC OUTLETS. HOW DIFFICULT IS IT TO PUT THEM ON MYSELF? THANKS.
   / How reliable is Kioti e.g. compared with Kabota? #60
I can't speak to your exact tractor, but on mine, the Rear remotes come as a kit, and I have looked over the install instructions in the service manual, and it doesn't look bad if you are reasonably mechanically inclined and can follow instructions. Also the good news is that the kits cost considerably less than the Kubota ones.
2024 JOHN DEERE 8R 280 LOT NUMBER 8 (A53084)
2024 JOHN DEERE 8R...
JLG 3248RS Electric Scissor Lift (A56857)
JLG 3248RS...
2019 Chevrolet Cruze Sedan (A53424)
2019 Chevrolet...
2019 Bobcat 3400 4x4 Utility Cart (A54811)
2019 Bobcat 3400...
2002 Alumitech Airboat with T/A Boat Trailer (A55853)
2002 Alumitech...
Toro 880 Procore (A55758)
Toro 880 Procore...
