How reliable are front mounted mowers? New Holland MC vs. Kubota F series?
   / How reliable are front mounted mowers? New Holland MC vs. Kubota F series? #1
mbleill
I am considering buying a front mounted mower 4x4 mower for my hilly property. How reliable are the different brands. I have looked at new Holland and Kubota. Any thoughts on others that I should consider? Reliability?
   / How reliable are front mounted mowers? New Holland MC vs. Kubota F series? #2
P1010001.JPGI have a New Holland MC 28. I have had it for over 10 years and I think it's the Cadillac of Mowers.
   / How reliable are front mounted mowers? New Holland MC vs. Kubota F series? #3
I have a JD front mower that is over 10 years old. It is not 4wd. When I was shopping I also looked at Kubota. But could not get close to the JD price. Have had almost zero problems. The NH looked good at the time but no dealers close by.
   / How reliable are front mounted mowers? New Holland MC vs. Kubota F series? #4
My TORO Groundsmaster is 17 years old, still going strong! You definitely want 4 wheel drive.
I use car ramps to access the blades.
Mowing the back of the dam, a 2 to 1 slope.
There a lot of used commercial out front deck mowers on eBay.
Thanks for the photos and information. I have a small vineyard with over 500 grape vines on the side of a hill that I have to mow between. I will definitely check out eBay.
   / How reliable are front mounted mowers? New Holland MC vs. Kubota F series? #6
Check out the threads on the F series down in the Kubota Lawn & Garden section. I have over 950 hours on my first F3680 and am trading for a second. Have not seen the NH front mount mowers around here but then again not too many other brands.
   / How reliable are front mounted mowers? New Holland MC vs. Kubota F series? #7
My Kubota F2260 (1998 Model) has almost 1300 hours on it. Last week I thought I was going to have to make my first ever repair on it (excluding normal scheduled maintenance). I turned the key and nothing happened. I checked the battery. It was good. I thought safety start switches. Long story short, the ground cable had come loose. Tightened it up and away I went. Another thing to consider is fuel economy. I purchased a new Ferris with a Yanmar engine for my other place. Great machine, but consumes about twice as much diesel fuel per hour as my Kubota. At half a gallon per hour more times 1300 hours and $4.00 per gallon, the Kubota would save me $2,600. If I would have known this when I purchased the Ferris, I would have looked harder at a new Kubota zero turn.
OrangeGuy
   / How reliable are front mounted mowers? New Holland MC vs. Kubota F series? #8
OrangeGuy
You need to find a place to buy off road diesel, $3.49 a gallon, on road $3.79, at the same station.
I just filled my off road tank last week.
   / How reliable are front mounted mowers? New Holland MC vs. Kubota F series? #9
Try a Ventrac the best Billy Goat in the biz.
Thanks Murf, It looks like it could be just what I am looking for. Is it a diesel? Can you tell me a ball park number that they sell for? Do you recommend a dealer? I live in south western Ohio but will be moving to south eastern Indiana near Brookville, IN.
Thanks, Mike
2017 Dodge Charger Sedan (A56859)
2017 Dodge Charger...
New/Unused Quick Attach Bale Spear (A57454)
New/Unused Quick...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2014 DRAGON PRODUCTS 130BBL VACUUM TRAILER (A58214)
2014 DRAGON...
2011 Komatsu GD655-5 Motor Grader, S/N 55088 C014007, PIN# KMTGD026P01055088, Turbo Diesel Engine, (A59076)
2011 Komatsu...
LOT OF 12' FLAT IRON (A58374)
LOT OF 12' FLAT...
