Mowing How powerful is a Kubota B2410?
   / How powerful is a Kubota B2410? #11
I'd like to see a pic of this.
I don't plan to mow again this year, so probably won't get a picture. I have a bracket mounted above the rear wheel on the bush hog, the arm on the trail mower attaches to that bracket. Here's a picture of it being pulled behind an ATV, looks the same behind the bush hog.
   / How powerful is a Kubota B2410? #12
Grass and weeds that high will get wrapped around the front drive shaft. Be sure to put some sort of skid plate under the tractor before trying to mow tall stuff.
   / How powerful is a Kubota B2410? #13
My local Kubota dealer took in on trade a 2001 B2410 with FEL. It has 210 hours on it and appears to be in pretty good shape other than a busted head light cover, etc. They want $8500 is this a good price.
What's the etc.?
For reference my 2007 B7610 (240hrs) w/ Fel, Box blade, trailer and several chains and load binders (as in sig) ran $11.5K in April 2009. I kinda valued the 7610 at about $9K. (GREAT trailer)
Also - remember hours may not represent reality. There's several threads on this but on my 7610 it only clocks an hour when run at speed, which is like 2600RPM
http://www.tractorbynet.com/forums/...150221-b7610-hour-meter-tach-revolutions.html.
http://www.tractorbynet.com/forums/owning-operating/164597-hour-meter-operation.html
When I run the backhoe at
The busted headlight cover was the only major thing that I noticed. Everything else visually checks out. The paint on the hitch is all chipped but that is what you should expect on a used tractor. The sheet metal is in good condition but I am sure there are other small details that I missed while looking it over.
   / How powerful is a Kubota B2410? #15
we have a b2410 and i pull a 6ft by 6ft chain harrow around every year and also we have a 1/2 tonn reco flail that i use regularly to mow the the grass, i've even had this tractor pull a 38ft static caravan in to poistion we've had no probs over the pulling/pushing power of the motor
2013 INTERNATIONAL REEFER TRUCK (A57880)
2013 INTERNATIONAL...
2016 Ford F-450 Flatbed Utility Service Truck (A56858)
2016 Ford F-450...
2008 Featherlite Portable Office Command Center T/A Trailer with Wacker Neuson G50 Towable Genera... (A56858)
2008 Featherlite...
2011 DOOSAN G25KW GENERATOR (A55745)
2011 DOOSAN G25KW...
2005 Interstate 7x14 Trailer (A55973)
2005 Interstate...
Husqarvana 46in Riding Mower (A56859)
Husqarvana 46in...
