How old is old gas?
   / How old is old gas? #1
dodge man
Super Star Member
West central Illinois
JD 2025R
I bought a generator about 3 months ago and its gas powered. I'm wondering how often to drain the fuel and change it out. I treat the fuel with Marine Stabil. I'm thinking every 3 to 4 months. Is the too often, not often enough? I'll probably take the older fuel and burn it in my truck.
   / How old is old gas? #2
It should be good for a year with Stabil. Start your generator once a month and to stop it shut off the gas. That way the carburetor will be empty preventing oxidation.
   / How old is old gas? #3
perhaps you can drain it out and use it in something like your car or lawnmower.. that way it always stays new. ie.. get it.. treat.. keep in tank for a month or two.. drain and use then add new?
soundguy
   / How old is old gas? #4
Old Gas... really old gas has a smell to it you will not forget... the best I can describe it is very strong and similar to varnish...
I occasionally come across equipment that has been stored for years... sometimes more than 20 years and all the problems that go along with it.
On another related issue... over one year ago, my brother filled the tank on his SeaRay 176BR carburetor 4 cylinder.... the boat has not moved.
At first I was thinking of syphoning it off for use in my daily driver vehicles... then I decided not to use it in anything with a CATALYTIC Converter or Fuel Injection...
At least with a full tank... there should not be much trouble with moisture...
   / How old is old gas? #5
I believe Stabil claims their product works for 12 months when in reality I have read and experienced it to be closer to 24 months (with the adequate dose).
I would just get on a schedule (fall or spring) and replace the gas once per year. In my opinion, even the ethanol gas is ok for this length of time provided it has been treated (i will do a double dose in smaller containers) and keep the tank full to prevent condensation.
I have never gone to the trouble of running something dry to prevent problems. I wouldn't think you would want to fuss with your generator to get it started after running it dry. When you need it, you need it right away. Properly stabilized gas and a full tank will easily last 12 months without causing problems. This is my experience in my part of the country. It could be different due to environmental factors. We do have high humidity at times though.
   / How old is old gas? #6
6 months is enough for me now days. I used to store gas for years but not now with this crap they sell. Marine Sta-Bil is good stuff though.
Chris
   / How old is old gas? #7
some may not agree but I think the best thing is to run it dry and i have never had trouble starting any of my stored engines that way. Some have been a couple years. I have been told that some seals and gaskets will dry out this way but some of those generators etc are a few years old when bought new and their seals and gaskets dont dry out. Works for me anyway.
   / How old is old gas? #8
I may be off base, but I think gas is actually more stable now than it used to be. Years ago, if you didn't run an engine for 3 months it would be hard to start. I've accidently left unstabilized gas in engines for 8 or 10 months recently and started with no problem. I agree with the idea of putting in stabilizer and keeping it full should give you a year plus with no problem.
   / How old is old gas? #9
I do this on most everything but I put shut off valves on the gas lines to do this. I then top the tank off. If I don't use the gas in it I then use my pump to take it out and run it in my boat. Only item I don't always use in 6 months is my generator.
Chris
   / How old is old gas? #10
Are you buying 100% gas or ethanol mixed gas? I've had trouble with ethanol gas in as little as 6 weeks. Could it be a climate related thing (middle TN-lots of summer humidity) ? Maybe my carb was already a bit dirty and the ethanol was all it took to push it over the edge...
2011 Nissan Rogue SUV (A53424)
2011 Nissan Rogue...
2012 JOHN DEERE 13-INCH REAR WHEEL SPACER FOR 10 BOLT HUB (A55301)
2012 JOHN DEERE...
40" WIDE STAIRCASE W/ METAL RAILING (A54757)
40" WIDE STAIRCASE...
UNUSED LANDHONOR SGB-11-72W 72" GRAPPLE BUCKET (A54757)
UNUSED LANDHONOR...
TOW BEHIND FINISH MOWER (A50324)
TOW BEHIND FINISH...
UNUSED SWICT 72" QUICK ATTACH BUCKET (A54757)
UNUSED SWICT 72"...
