How often to sharpen.
   / How often to sharpen. #11
I think what some miss is that when your chain gets dull it generates heat. Too much heat and the metal will lose its temper and never hold a sharp edge well again. I do every other tank of gas unless I am cutting real tough wood. Then more often.
MarkV
   / How often to sharpen. #12
Much depends on the hardness of the saw chain itself. I find I can go from 2-3 tanks with a Stihl chain but no more than two with a Husky chain when sawing oak. Oregon, Carlson and the like somewhere in between. In my mind, sharpen a chain only when it needs it and to me , that does not mean when you are making dust as opposed to chips. Anyone who has cut wood to any degree can feel when you are losing cutting efficiency. It is at that point where I mean as needed. The best edge comes from the factory. I like to keep that edge as long as possible. I once got 4 tanks out of a Stihl chain but that is not the norm.
   / How often to sharpen. #13
My sharpening frequency varies with the type and condition of the wood . If it's something like Locust with a lot of dirt , I may only get at tank out of the chain . In clean wood , I'll go until the chain starts to loose cutting performance . Generally I don't sharpen a chain while cutting, I just change it out .
At the end of the day , I sharpen the chain (s) in the shop . At this time I go through things like cleaning the bar groove , check the air filters ,etc.
   / How often to sharpen. #14
My sharpening vries by chain, and what I am cutting.
Stihl chain is the best, and holds an edge better than anything else I have seen.
I sharpend a little less frequently now. I thought I was doing a good job with a basic file and guide. Wrong... I got an Oregon clamp on sharpener. My chains are sharp sharp sharp now. Amazing the difference.
I still touch up a little with just a file, but put it on the jig every other sharpening.
I also carry at least one extra chain, that is sharp.
I found:
- use good bar oil
- use good chain
- use a good sharpening guide; I thought I was doing good before the Granberg style jig...
- Keep the chain out of the dirt, rocks ect
- If you do ding a rock or dirt, swap the chain right away till you can clean/sharpen
- Dont let the chain get dull. Then it usually gets hot too, which affects the temper of the cutting edge. Then it will never hold an edge
- Keep the bar clean, groove maintained, sides filed ect.
- Read the Oregon sharpening and chain care webpage. Great info and resource
One reason I asked this question is I somehow thought a chain should stay sharp for several tanks of gas. I've found out I pretty much need to sharpen it at least every other tank of fuel. Like others have said, it just depends on what your are cutting.
   / How often to sharpen. #18
As said it depends on the type of wood and wether it's dirty from skidding etc . Personally i just go by the way it's cutting but on a normal day of 7-8 tanks of gas cutting poplar i'll sharpen 2-3 times but cutting oak thats been dirty from skidding i'll sharpen every tank of gas. I do like to sharpen by hand to get it just right and must admit that i have now put stihl chain on all my Jonsered,Husky,dolmar and stihl saws for many reasons, Dont know why but the oregon chain we've been getting of late has been very poor quality.
2008 MACK CHU613 TRI AXLE 16FT DUMP TRUCK (A58018)
2008 MACK CHU613...
UNUSED FUTURE 350 HYD BREAKER HAMMER (A52706)
UNUSED FUTURE 350...
PICKUP TOOLBOX (A58214)
PICKUP TOOLBOX...
2006 JLG 450SJ SERIES II TELESCOPIC BOOM LIFT (A52709)
2006 JLG 450SJ...
2019 Ford F-150 XLT Sport Pickup Truck, VIN: 1FTEW1EP3KFA58619, Crew Cab, 4 x 4, 2.7 L EcoBoost Gas (A59076)
2019 Ford F-150...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A52708)
KNOW BEFORE YOU...
