How often to sharpen.
   / How often to sharpen. #1
dodge man
Super Star Member
West central Illinois
JD 2025R
How often do you sharpen your chain? I find I usually need to sharpen mine after every 1 or 2 tanks of gas. Sometimes I just touch it up with a file, while sometimes I use my electric sharpner. Is this too often?
   / How often to sharpen. #2
Every other tank seems to be the standard.
   / How often to sharpen. #3
It really depends on what you're cutting...
Guy's that have never tried to cut something like a 'Queen Palm' (Cocus Plumosa) would not know what to think...
If you've never done it you would think you were cutting into a hunk of metal...the viens in the trunk of the palm are big enough to allow fine grains of sand with water which make them (palms) notorious with tree cutters for destroying chains...a new chain will be dull before the first cut is complete on older larger trees...
in the same respect the bark of most other trees will contain some solid minerals and is often harder on chains than the core wood...
   / How often to sharpen. #4
Assuming you haven't hit any dirt, rocks, or metal in the wood, every other tank of gas will work very well.
   / How often to sharpen. #5
I don't bother with a time frame so to speak{every gas fill or every other etc}. Different wood and different circumstances cause different ways of wearing. I'd rather touch them up to much then not enough. A dull chain can raise cain with a bar causing premature wear.
   / How often to sharpen. #6
When it gets dull??:eek:
Seriously I look at the chain everytime I stop to fill the saw -- you can feel a dull chain when cutting but the frequency of sharpening is dependant upon what you are cutiing and what you hit. This weekend I was cutting old piles of cedar -- ran though about three tanks of gas and did not have touch the chain. Weekend before that was cutting ironwood (Hop Hornbeam) --- sharpened every tank:(
   / How often to sharpen. #7
Feel the chain teeth [both sides] with the back of your fingernail. When it wont grab your nail sharpen it.
larry
   / How often to sharpen. #8
I sharpen (touch up with the file) after every tank, regardless.
I find the "touch" test doesn't tell much.
Take a look at the edges of the teeth with a 10x hand lens after sharpening, and again after a tank of fuel. You will see the difference quickly, even when good clean cutting with no dirt on the logs.
A good edge makes for great cutting.
But I've noticed over the years, that different sharpness is ok for different folks. But I'll go with more strokes. :D
   / How often to sharpen. #9
I'd also like to add, if your having to force/work the saw through the wood it is dull. My saw is running correct and properly sharpened when it basically cuts under its own weight. You should be able to set the saw on the wood and it will dig in and cut. If you're applying pressure then IMO it is dull.
   / How often to sharpen. #10
That's my rule of thumb, if I have to force it, it's dull. Also, you can look at the chips and tell if it needs touched up. If it's making something closer to saw dust than wood chips, it's dull.
2018 JOHN DEERE 204L WHEEL LOADER (A51242)
2018 JOHN DEERE...
HANG ON 48" CATERPILLAR FORKS (A51242)
HANG ON 48"...
Bill 528 Grain Cart (A50774)
Bill 528 Grain...
2006 INTERNATIONAL 4300 DT466 SBA 4X2 BUCKET TRUCK (A51406)
2006 INTERNATIONAL...
2016 Hurricane Blo-Vac X3 Stand-On Blower (A50324)
2016 Hurricane...
2008 VOLVO VHD64B CRANE TRUCK (A52141)
2008 VOLVO VHD64B...
