How often should a MMMower be greased?
   / How often should a MMMower be greased? #1
Botabill
Platinum Member
Ontario
How often should a Mid Mount (54 inch) be greased. I know you can't over grease but does anyone actually know what the maximum number of hours I can wait. I hate pulling the mower out from under the machine. I guess a second question is does anyone have the trick to hooking up the shaft to the tractor under belly PTO that doesn't include skinned greasy knuckles and require double jointed body parts. Thanks. Bill.
   / How often should a MMMower be greased? #2
The owners manual says every 10 hrs. I grease mine every other time I mow, because I pressure wash my tractor after every use. Greasing the driveshaft is the hardest zirk for me to reach. My dealer told me to run the blades after washing to remove the water around the pulleys too.
   / How often should a MMMower be greased? #3
The mower will get easier to get on and off the more you do it. I find it easier to jack up the back of the tractor a bit when reinstalling the MMM. IT is much easier to hook up the PTO shaft with a couple of inches of elevation.
Make sure that both sections of the shaft are clean. The male end on the tractor and the female end on the PTO shaft. I usually give both a squirt of WD40 too. The locking collar thing on the PTO shaft can be a bit of a pain too. I find it easier not to try to hold it back. Slip the PTO shaft on the tractor THEN pull the locking collar back and slide the shaft the rest of the way on.
   / How often should a MMMower be greased? #4
Have you tried getting multiple grease guns with different hoses and such? I have a half dozen and use them for different places. Short steel tube, long steel tube, short flex tube, long flex tube, side ways adapter, hand squeeze, etc.
   / How often should a MMMower be greased? #5
I have a BX23 with a 60" mower, I honestly find taking the mower on/off easier than any other part of the machine. I do it on the garage floor and all I do is slide it under the machine, I don't even spin the wheels around, they slide on the concrete just find. The shaft collar holds itself back. I attach the shaft to the machine before any other connection and then it is REALLY simple from there. Sometimes I need to fool with the shaft some and try two or three times before it lines up but I just take my time.
I grease every time I use it. I use the same wheel bearing grease that I put in my boat boat trailer bearings, it is a white grease.
   / How often should a MMMower be greased? #6
I grease whenever I remove the blades to sharen: min. 1 time/year.
Grease the PTO coupling really well and use finesse, not force when coupling.
AMR, I also put on smooth concrete floor but made a dolly from 1/2"ply and 16 two inch swivel casters. This really makes moving the deck around easy. No wheel pivoting and no wear on the wheels. Ply was cut to exact silhouette of deck skirt.
   / How often should a MMMower be greased? #7
I try to keep it simple and grease every 10 hrs on the hr meter. I don't drop the MMM to grease it, I leave it mounted.
Recently I noticed the MMM getting louder when I was knocking down a couple acres of pretty high growth. Afterwards I dropped the MMM pulled the blades and cups then counted the "pumps" it took to start squeezing ont of the spindles. It took about 7 more pumps than the normal of 5. Not surprisingly the MMM was back to being very smooth and quiet afterwards.
So what I recommend is to never go over 10 hrs and grease sooner if the MMM "sounds" like it could use it.
Volfandt
2022 CATERPILLAR 242D3 SKID STEER (A60429)
2022 CATERPILLAR...
2016 AutoHauler CX11HCSD T/A Car Hauler Trailer (A56858)
2016 AutoHauler...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
1987 CATERPILLAR D6H HIGH TRACK CRAWLER DOZER (A59823)
1987 CATERPILLAR...
CATERPILLAR 108" WHEEL LOADER RAKE (A52707)
CATERPILLAR 108"...
2011 Toro Workman HD Utility Cart (A59228)
2011 Toro Workman...
