how often do you service your tractor?
   / how often do you service your tractor? #21
Engine oil and filters at 200-250hrs and rear end filters every 1000hrs or so .
   / how often do you service your tractor? #22
I'd always cahnge the filter when i did the oil.. and in your case, I'd do the tranny fluid every 2ys or 1200 hrs.. whatever came first.
soundguy
   / how often do you service your tractor? #23
Like Roy :), I had never changed my coolant in seven years and 1075 hours. My bad, but it always looked clean and my tractor is kept in a garage that stays above freezing all winter. The recommended interval is three years.
That was on today's to do list. When I flushed the radiator and block with the engine running and hose stuck in the radiator cap hole per the instructions in the manual, not a speck of sediment, nor a drop of rusty water to be seen. The water was shooting out the engine block drain in a nice even, strong, clear stream.
I was thinking antifreeze and metallurgy have come a long ways since the 1960's. :)
Dave.
   / how often do you service your tractor? #24
does that tc 40 need the fw15 addative?
soundguy
   / how often do you service your tractor? #25
soundguy
That's something I want to check on more after reading the 'Which Antifreeze' thread. The manual just says 50-50 mix of distilled water and 'permanent antifreeze'. I bought the pre-mixed Prestone extended life stuff to avoid putting our well water in it. My guess is that if something special were needed, NH would have their own branded antifreeze and specify that.
The manual doesn't decribe the cylinder type, sleeved or parent bore, which I guess is what makes a difference for cavitation issues?
Dave.
   / how often do you service your tractor? #26
My guess is that if something special were needed, NH would have their own branded antifreeze and specify that..
uh.. well.. they kinda DO.. they sell the FW15 addative....
soundguy
72" HYD QUICK ATTACH GRAPPLE (A51406)
72" HYD QUICK...
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A51692)
2015 Peterbilt 320...
2020 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A54607)
2020 INTERNATIONAL...
UNUSED (2) 7000# DROP AXLES W/ BRAKES (A54756)
UNUSED (2) 7000#...
FORREST RIVER CHEROKEE CAMPER (A52472)
FORREST RIVER...
2013 BMW X5 xDrive50i AWD SUV (A55758)
2013 BMW X5...
